Go to Post "You are the lead programmer now, therefore everything that goes wrong is your fault. When anything good happens its the teams fault." "But what if the robot spontaneously combusts?" "Your Fault." ~Borna - CodeTBone [more]
Unread 02-01-2008, 06:57
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: pic: 2 speed tranny
Originally Posted by Hachiban VIII View Post
...a crash shifting transmission looks simpler to build than a dog-shifting one. I wonder why more teams don't do it. Why did you choose crash-shifting over dog shifting?
Can somebody clarify the differences between crash shifting and dog shifting for those of us in the peanut gallery?
Mark
Brick walls are for other people. - Randy Pausch
Unread 02-01-2008, 08:30
in between teams
AKA: Luke Van Oort
Crash shifting (also sometimes referred to as blind shifters, 116-style shifters, sliding gear shifters, and gear munchers) is when you have gears slide to engage a different set of gears like so:
Dog shifting (also sometimes referred to as 45-style or 716-style shifters, depending on the dog design) engages a set of gears by using a 'dog' to lock to the shaft one of a pair of freewheeling gears. Like so:
The orange part is the dog, green and blue are the freewheeling gears, red part is the output shaft, and the yellow part is the shifting rod that actuates the sliding action of the dog. (The shifter appears to be in the middle of shifting and the dog isn't really engaging either of the gears)
Team 1219: 2009 - Mentor
Unread 02-01-2008, 10:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
While that piston orientation save a ton of space, it looks like a royal pain to install and maintain. Is there a good reason not to just turn your two clearance holes into notches so the piston can be removed with the pneumatic fittings still in place?
Unread 02-01-2008, 14:42
CraigHickman
Posts: n/a
Very nice! Not sure what all the complaints are about, this looks like a very solid design! 3.2 pounds is amazingly light for a 2 speed shifter. I believe the only thing lighter was the 254/968 gearbox, but that thing was just insane.
Looks very, very nice. What made you go with crash shifting, instead of dog shifting, or a ball lock alternative?
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
pic: Dual FP KOP Tranny Andy Brockway Robot Showcase 5 06-02-2006 11:41
pic: Team 1501 Tranny Wayne Doenges Robot Showcase 8 19-02-2005 02:52
It's Back! 4-Speed Shift-On-The-Fly Tranny. New and Improved! Travis Covington Robot Showcase 16 16-02-2005 18:28
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
