Re: Analog to digital converter confustion
Adam,
Samples per second and Hertz mean the same. MSPS are Mega samples per second, just a different order of magnitude. What exactly are you looking for? |
The problem is that Mouser lists twenty different variations of the same unit which makes it a pain to search for parts. I just wanted to make sure that msps, MSPS, MHZ and MSPs all meant the same thing.
Adam,
You might have better luck searching Digikey's database and either buying from them if you have some other stuff to make it up to the minimum order, or cross-checking with Mouser to see if they have the particular part. If you don't mind narrowing to a specific vendor a priori, you could also go straight to Analog Devices and use their parametric filters to pick out your chip. If you only need one or two, you might even just be able to get a sample from them. |
For ADCs, I tend to just go to analog's webpage directly (www.analog.com). They have a rather decent interface for selecting an ADC, and they tend to have decent prices. Even better, they'll sample you a handful of just about anything!
Could you post your specs for us? How many inputs? How many bits of resolution? How many samples per second? What type of digital interface? Voltage requirements? |
#8
AD9280 8bit 32MSPS 2.7V-5.5V $2.15 AD9200 10bit 20MSPS 2.7V-5.5V $2.50 AD876 10bit 20MSPS 4.5V-5.25V $3.31 Analog TI has a few more. As does Linear Bits Speed ADCs S/H SINAD Power Supply Voltage Range Packages LTC1406 8 20 1 1 48.5 150 5V SSOP-24 LTC1741 12 65 1 1 72 1,275 5V TSSOP-48 LTC1742 14 65 1 1 76.2 1,275 5V TSSOP-48 LTC1743 12 50 1 1 72.2 1,000 5V TSSOP-48 LTC1744 14 50 1 1 76 1,200 5V TSSOP-48 LTC1745 12 25 1 1 72.5 380 5V TSSOP-48 LTC1746 14 25 1 1 77.5 390 5V TSSOP-48 LTC1747 12 80 1 1 72 1,400 5V TSSOP-48 LTC1748 14 80 1 1 76 1,400 5V TSSOP-48 LTC1749 12 80 1 1 71.7 1,450 5V TSSOP-48 LTC1750 14 80 1 1 75.2 1,450 5V TSSOP-48 |
#9
Eric,
It's not the supply range that's critical (as you pointed out, there are tons of 5 V parts), it's the analog input. With those specifications, it is really hard to find a suitable A/D. Last edited by Manoel : 04-01-2008 at 12:52. Reason: hate to mispell someone's name... |
#10
Edit: The signal is the percentage of ones compared to zeros in sample. Last edited by Adam Y. : 04-01-2008 at 13:24. |
#12
Adam, what resolution do you need?
| Analog-to-Digital Converter Code | Kevin Watson | Programming | 29 | 17-02-2008 13:07 |
| Digital to Analog Converters | 6600gt | Programming | 11 | 08-02-2007 23:27 |
| Digital to OI Analog | marcan | Control System | 33 | 05-02-2007 12:46 |
| Analog / Digital IO Connectors | Aidan F. Browne | Control System | 4 | 06-02-2005 22:26 |
| Analog vs Digital inputs? | f22flyboy | Programming | 8 | 08-11-2002 22:18 |
