Go to Post What no one knows is that I’m actually wearing fishnet stockings under this gown… as soon as they finish taking all of these darn photos I’m going to show Dave and Amanda who really has the best legs in FIRST!!! - MissInformation [more]
Unread 02-01-2008, 12:51
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Analog to digital converter confustion
Im looking for an ADC on Mouser. I have been given a specific sampling rate. Unfortunatly, the rate seems alternate between samples per second and hertz. Even that fact is not entirly consistent as Im finding MSPs and MSPS. Is there any significance to this or am is it just a matter of semantics?
Unread 02-01-2008, 13:18
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Analog to digital converter confustion
Adam,
Samples per second and Hertz mean the same. MSPS are Mega samples per second, just a different order of magnitude.
What exactly are you looking for?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 02-01-2008, 13:31
Adam Y.'s Avatar
Adam Y.
no team (?????)
Originally Posted by Manoel View Post
Adam,
The problem is that Mouser lists twenty different variations of the same unit which makes it a pain to search for parts. I just wanted to make sure that msps, MSPS, MHZ and MSPs all meant the same thing.
Unread 02-01-2008, 13:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Adam,
You might have better luck searching Digikey's database and either buying from them if you have some other stuff to make it up to the minimum order, or cross-checking with Mouser to see if they have the particular part. If you don't mind narrowing to a specific vendor a priori, you could also go straight to Analog Devices and use their parametric filters to pick out your chip. If you only need one or two, you might even just be able to get a sample from them.
Unread 02-01-2008, 19:38
For ADCs, I tend to just go to analog's webpage directly (www.analog.com). They have a rather decent interface for selecting an ADC, and they tend to have decent prices. Even better, they'll sample you a handful of just about anything!
Could you post your specs for us?
How many inputs?
How many bits of resolution?
How many samples per second?
What type of digital interface?
Voltage requirements?
Unread 03-01-2008, 09:05
Adam Y.'s Avatar
Adam Y.
no team (?????)
How many inputs?
The ability to measure 5 volts and 20MSPS are the only requirments I really care about. I'm pretty sure that Im botching something up or looking at the wrong specification because I can find the 20MSPS but I can't find the five volts. Im assuming that 2Vp-p means 2 volts peak to peak. Im even apt to using a DSP.
Unread 03-01-2008, 10:57
Unfortunately, that's a pretty extreme specification and I don't think you're likely to find anything that will meet both of those at the same time. You'll probably have to relax one of those requirements to get a chip you can work with. If you really absolutely have to measure signals in the 10MHz range for some reason, then I think your best bet is to run your signal through a high bandwidth op-amp first with a gain of .5 or some such so you can look for ADCs with a smaller input range. I'm pretty certain that even switching to a DSP won't help, as the faster DSPs tend to need 3.33V supplies or less.
Unread 03-01-2008, 12:58
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
Adam, what resolution do you need?
Unread 03-01-2008, 16:04
Adam Y.'s Avatar
Adam Y.
no team (?????)
Never mind. I just talked to my boss and he basically told me that anything about 10MHz, 2Vp-p, and 16 bits. Fortunatly, this actually means I can use a DSP.
Unread 03-01-2008, 23:15
I have to respectfully disagree with you here Kevin. I have found the following 20MSPS 5V parts in 15 minutes of searching.
AD9280 8bit 32MSPS 2.7V-5.5V $2.15
AD9200 10bit 20MSPS 2.7V-5.5V $2.50
AD876 10bit 20MSPS 4.5V-5.25V $3.31
Analog
TI
has a few more.
As does Linear
Bits Speed ADCs S/H SINAD Power Supply Voltage Range Packages
LTC1406 8 20 1 1 48.5 150 5V SSOP-24
LTC1741 12 65 1 1 72 1,275 5V TSSOP-48
LTC1742 14 65 1 1 76.2 1,275 5V TSSOP-48
LTC1743 12 50 1 1 72.2 1,000 5V TSSOP-48
LTC1744 14 50 1 1 76 1,200 5V TSSOP-48
LTC1745 12 25 1 1 72.5 380 5V TSSOP-48
LTC1746 14 25 1 1 77.5 390 5V TSSOP-48
LTC1747 12 80 1 1 72 1,400 5V TSSOP-48
LTC1748 14 80 1 1 76 1,400 5V TSSOP-48
LTC1749 12 80 1 1 71.7 1,450 5V TSSOP-48
LTC1750 14 80 1 1 75.2 1,450 5V TSSOP-48
Unread 04-01-2008, 09:03
Manoel's Avatar
Eric,
It's not the supply range that's critical (as you pointed out, there are tons of 5 V parts), it's the analog input. With those specifications, it is really hard to find a suitable A/D.
Brazilian Machine
Team # 383
Last edited by Manoel : 04-01-2008 at 12:52. Reason: hate to mispell someone's name...
Unread 04-01-2008, 09:36
Erik,
Ditto Manoel. He was originally implying he wanted 5V p-p input range and said himself he could only find 2V p-p devices. No one makes them since few people want, need or try to directly sample RF signals without any buffer or filter circuitry. Thus all the devices out there expect a 2-3V p-p signal so the device designers don't have to trouble themselves compensating for voltage levels near the rails, making a difficult task even more so.
Unread 04-01-2008, 12:03
Adam Y.'s Avatar
Adam Y.
no team (?????)
You are right. Of course in my infinite wisdom I end up picking a sigma delta converter. Anyone ever use these before or should I go back to the drawing board?
Edit:
The signal is the percentage of ones compared to zeros in sample.
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
Digital to Analog Converters 6600gt Programming 11 08-02-2007 23:27
Digital to OI Analog marcan Control System 33 05-02-2007 12:46
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
