Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 02-01-2008, 16:38
CraigHickman
Posts: n/a
pic: 114 is thinking of what?!
Unread 02-01-2008, 16:44
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: pic: 114 is thinking of what?!
I know that both 968, and 254 used the Fisher Price motor with the AM planetary gearbox in their 06 drive. They had to replace quite a few FP motors in this setup, but my understanding is that this was due to a problem with the AM gearbox which has been fixed in the newer version.
Unread 02-01-2008, 16:57
Brandon Holley's Avatar
what is on the shaft of the fisher price that is driving the rest of the gearbox? i can't see anything??
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 02-01-2008, 17:00
CraigHickman
Posts: n/a
That's where the pinion gears go. I have the bad habit of not putting them in, as we have a rather large box of Boston 14 tooth pinions in the lab....
Unread 02-01-2008, 17:21
in between teams
AKA: Luke Van Oort
I imagine it would work fine. Recently, I was working on a plan to mod AndyMark 2-speeds to add FP w/ AM planetary, in addition to the 2 CIMS; when I "ran the numbers" (ie used JVN's old calculator to model the combiner), the load was perfectly acceptable. My gearing plan slightly different (faster low gear, slower high), but the predicted FP current draw to slip the wheels was 13 amps in low gear and 32 in high. I wouldn't want to get into an extended pushing match in high, but the motor should last fine if you try to only push in low.
Team 1219: 2009 - Mentor
Unread 02-01-2008, 17:23
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
294 used the Fisher Price motor with the AM planetary in our gearbox last year. We had no problems with it over heating.
http://www.chiefdelphi.com/media/img...33da13ab_l.jpg
Ryan
Unread 02-01-2008, 17:29
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
We usually put a FP in addition to the two small CIMs. No problems with overheating, but be very careful to wire it correctly. We accidentally wired the practice ones backwards, and as the FP isn't powerful enough to overcome the two CIMs we didn't notice until they were both burned out in a blaze of magic smoke and smell.
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Where you might have problems with the FP motor is under stall conditions, my understanding is that they smoke if they have power applied and aren't able to turn because of too much of a load being applied (ie. good traction, and an immovable object in the way). The armature has low thermal mass, and heats up real quickly...no way to put a heat sink on it either, that I know of.
Unread 02-01-2008, 19:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm curious as to why you chose to use 3 motors per side.
You're going to be traction limited in low gear at 4 FPS, whether you use 2 motors per side, or 3.
You aren't going to push anyone in high gear anyways, so the only benefit from an extra motor I see is slightly lower current draw (I assume you're dropping the center wheel, in which case it doesn't even matter).
Seems like unnecessary effort, and extra weight, for not much of a tangible benefit.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-01-2008, 19:54
CraigHickman
Posts: n/a
Actually, this is designed for a tank track. We're not really traction limited with around 60 inches square of red linatex on the ground. (I haven't really taken physics yet, so correct me if that's flawed. A discussion with a mentor yielded that answer). There's no middle wheel to be lowered. As for not pushing someone in high gear, you never really know when you're going to get defended against, and not be practiced enough to downshift before the pushing begins.
Unread 02-01-2008, 20:23
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
To my understanding, that shouldn't matter. Friction (which determines your traction) does not really change based on surface area. There was a discussion about this in the Technical Discussion forum a few weeks ago. I think the linatex has a higher coefficient of friction (compared to the rubber gum or blue nitrile), which would result in a slightly higher available friction force, which would result in being able to push somewhat stronger. However, I don't think that the added torque from the third motor would really make a difference, as with the gear ratio already in place, your maximal torque would already be well above the maximal traction you can get.
Unread 02-01-2008, 20:32
in between teams
AKA: Luke Van Oort
Your conjecture is, in fact, flawed. On an ideal surface, friction and surface area are unrelated. FIRST carpet is not an ideal surface; however, I have never seen any conclusive evidence to support the idea that surface area and friction on it are related. (Unless you have real rigid 'spiky' traction materials, like 71's 2002 file cards or the old Technokat tread designs, but those have been illegal since 2003?, so that isn't really relevant)
Since red linatex has a mu of 1.6 instead of the mu of 1.3 that I did my earlier calcs with, I need to revise what I said. Most definitely, do not use this design if you intend to push in high gear; the FP will be drawing a bit over 41A, which is 65% of a FP's stall current. I do not think that this will last too well. You may not get a sudden smoking of the FP (well, if you push a lot in high you will, but not if it is just a tad here and there), but I think you will probably slowly loose power as you melt insulation on the windings, which causes windings to short out, reducing power. In low gear, you are still fine; the FPs only draw 15A. If I intended to use a gear for pushing, I would feel comfortable with FPs drawing 16A at the traction limit, but not much more than that.
On a sidenote: when trying to do drivetrain calculations, has anyone else been getting 403 forbidden errors when trying to use Google calculator due to their query looking like something malware would produce.
Last edited by lukevanoort : 02-01-2008 at 22:02. Reason: whoops, 71 ran file cards in 2002, not 2003
Unread 02-01-2008, 21:46
Cory's Avatar
AKA: Cory McBride
It's been proven time and time again that surface area does not affect traction.
One case in which it would is like someone said with Beatty's file cards (or velcro, etc). If you have something actually interlocking with the fibers of the carpet, it would take more force to displace you.
Since those treads are totally smooth, with no raised tread profile, you can't even mimic that interlocking action between carpet fibers and your tread material.
P.S. Without a dropped idler on your treads, I think you may find turning in high gear to be pretty poor. Practically every successful treaded robot I've seen lately drops the center idler to shorten the effective wheelbase.
2001-2004: Team 100
Unread 02-01-2008, 21:56
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
Just so everyone knows.
Coefficent of friction is not static value with rubber. As the weight per square inch decreases the coefficent of friction actually goes up. This was proven by several different experiments that are posted in the thread that you mentioned. So assumeing 1.6mu is fine for baseline calculations but will vary depending on how you implement it. The mu vlaue could increase by 20%or more depending on implementation.
So the euqation is:
mu*Normal force="Tractive Force"
If you normal force stays the same but your mu goes up by 20% you will see a 20-30% greater tracitve force thus
1.2mu*Normal Force = 1.2Tractive Force
(I use the term tractive force to mean the force that you must apply to break staic friction and start relative motion between the ineracting materials.)
Just so you know manual labor the outback tracks have a pivot wheel so you don't get the full length of engagement on the tracks. So change 60 inches of engagement to about 30 inches but it is still 5 times the engagment of a 6wd robot.
I hope some day to do an exhaustive experiment to settle this question once and for all but I don't have the time or the money right now.
Unread 02-01-2008, 22:40
CraigHickman
Posts: n/a
I really, really don't want this to turn into one of the other 50 threads on CD about surface area v. traction. So please, let's focus on a gearbox, not on a debate that's raging elsewhere.
pic: 114: How we roll CraigHickman Extra Discussion 27 19-04-2007 20:46
pic: 114 Tread V 2.0 CraigHickman Extra Discussion 4 08-01-2007 01:34
pic: What is 114 cooking up? CraigHickman Technical Discussion 13 20-06-2006 10:19
pic: 114: Stripped! CraigHickman Robot Showcase 5 04-04-2006 23:49
pic: 114 wheels CraigHickman Robot Showcase 12 31-01-2006 15:50
