Go to Post You know this crazy ChiefDelphi... nothing but useless information and kids ranting about pizza. - Amanda Morrison [more]
Unread 03-01-2008, 09:59
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Downloading from laptops
I have a very weird problem downloading. I can download successfully from any of my desktop machines but I can't download using any of my laptops. All of my laptops have RS232 ports on them so I'm not using any USB-RS232 converters. I have three different brands of laptops (Dell, Toshiba, Gateway) and the problem exits on all of them.
Is there some secret setting to the COM ports that I have to adjust? I've tried just about everything that I can think of. The IFI loader seems to set up the uart with its own values anyway.
The symptoms vary for different download attempts. Usually, the robots stays in download mode after the download completes. But sometimes, I get a hex dump in the terminal window.
The problem doesn't seem to happen when our executable is smaller, If our manipulator code is missing or the camera code is missing, it is more likely to succeed. Sometimes, the full download succeeds but that is rare.
Does the IFI loader use CTS/RTS or does it try to use X-on or X-off? I've messed with the buffers setting for the com ports but that doesn't seem to help either.
I find it odd that I can almost always download with my desktop machines. Most of the desktop machines are running Windows 2000 while the laptops are running XP. I have on Desktop that is running XP and that seem to download OK.
Is there some secret IFI loader setting or COM port setting or, perhaps, some XP background task that is bumping the download? The progress bar on the laptops seems to move slower than it does on the desktop machines but I haven't actually timed it.
Has anyone seen this problem? We've had it since the regionals last year.
Unread 03-01-2008, 11:03
Re: Downloading from laptops
This sounds like what would happen with an outdated version of the IFI Loader program. What version are you using on the laptops?
Unread 03-01-2008, 12:40
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Silly question: have you tried some different cables? Are you using a full cable and not a homemade one? You could ask the cts/rts question on the IFI's forums.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 03-01-2008, 12:52
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
Another thing to try is to make sure that the laptops are plugged in to AC Power when you try to download the code. I've found that sometimes that helps.
Unread 03-01-2008, 14:57
FRC #0138
I've tried several different cables and there does seem to be some effect in that the few times it succeeds is when the cable is very short. All our cables are commercially made.
The loader is 1.1.0 which was update in Feb07.
The laptops are always run with the AC adaptor.
Unread 03-01-2008, 20:09
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Try going to the control panel, then click on system. Once in sytem go over to hardware, and make sure all settings are correct, and that the loader is sending the code to the correct port. We had this problem a few years and I cant remember what we did after we got to the hardware screen, sorry.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 03-01-2008, 21:30
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Have you tried reinstalling the loader? You probably have already thought of this, but that may work if you haven't...
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 03-01-2008, 21:36
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
It also does wierd things on the computer if the user does not have administrative privledges. If they don't try making an accont that in admin and seeing if it will download for that account.
ALWAYS a mechanical problem!
Unread 04-01-2008, 09:35
FRC #0138
I've been to the com port system dialogs more times than I can count. I've re-installed the IFI loader several times and tried out old and new versions.
I don't recall checking for admin privledges. I'll check that out tonight.
We don't have problems downloading to the 2004/2005 controllers and we don't have problems downloading smaller executibles.
The weird thing is that it always works from the desktop machines and almost never works from laptops.
Unread 04-01-2008, 17:26
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Have you tried to change the com port setting on IFI loader until it finds one that works? I've had that issue before.
-Mike
Unread 04-01-2008, 18:42
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
I had a similar problem recently. I couldn't download to the Vex controller from my laptop, but I could from several desktops. Results varied, but it would either fail to start downloading, fail halfway through, fail 1/3 through, fail 3/4 of the way through, etc. It was very strange.
I completely reinstalled Windows XP recently, reinstalled everything and it works perfectly every time, so I don't know what was wrong with it the first time.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 05-01-2008, 01:33
FRC #0138
I now have one of my laptops working and I'll try getting the others to work tomorrow.
I noticed that programs that were smaller than 0x8000 would download correctly while larger ones would not.
I also noticed that the IFI loader that ran on the desktop machines would print out that they were Erasing banks 1-8 but the laptop machines did not. The printed out a message that said it was erasing memory but nothing about bank numbers.
I found in the ifiloader directory in Program Files an INI file. This file has a variable called debug_level that was set to 0. I thought that I might get some insight if I raised this level so I edited the INI file to set the debug_level to 1
As soon as I did this, the loader started printing out the messages about erasing banks 1-8 and now larger executables download successfully. I was curious if this variable was set on my desktop machines. It is not set.
I went back to the laptop and changed the INI file back to its original state. The IFIloader still works!. I appears that changing the INI file somehow fixed the problem but changing it back does not cause the problem to reappear. IFIloader might write something into the registry but I couldn't find anything.
As I said, I'll try doing the same trick to the other laptops and see if that magically fixes things.
HP Laptops Beth Sweet Chit-Chat 23 28-05-2006 20:53
Downloading Video from a Camcorder woes Ian Curtis Chit-Chat 4 14-09-2005 21:13
Laptops Mike Chit-Chat 23 30-05-2005 19:52
Problem Downloading from Streamline petek Inventor 2 10-03-2005 21:07
