Go to Post That's some sexy use of aluminium - Bharat Nain [more]
Unread 03-01-2008, 14:17
SidneySalvo SidneySalvo is offline
FRC #1691
SidneySalvo is an unknown quantity at this point
Probem transfering program from easyC to bot
So here is my problem, I have built a program in the easy C application, but when i try to transfer the program over to the bot thru a usb-to-serial cable, the computer doesn't recognize the bot controller. I have tried pressing the program button on the cable but that simply makes the program status light blink green, when it is supposed to turn solid orange.
If anyone one knows what we are doing wrong or has been in this situation before, please give me any advice that you have.
Unread 03-01-2008, 14:26
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Probem transfering program from easyC to bot
Do you have the correct year selected in EasyC for the type of control panel you are using, and is the usb-to-serial cable plugged into the correct usb port on the computer end? These are the common mistakes that trip me up all the time.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 03-01-2008, 14:27
Mr.D's Avatar
Mr.D Mr.D is offline
Randy Decker
FRC #0829 (Warren Robotics "The Digital Goats")
Mr.D is just really niceMr.D is just really niceMr.D is just really niceMr.D is just really nice
Make sure you are connected to a port other than Com1 or Com2 as shown in the attachment.
If unknown is shown anywhere, one of the USB ports is not connected to the controller. Coms 1 and 2 are the serial ports and do not connect to the USB connector.
Hope this helps, it was an issue with our controllers.
Name:	EasyC LoaderSetup window.JPG
Randy Decker
Computer/Networking Technology, PLTW DE/IED,
and Electronic Systems Technician Teacher
Walker Career Center
Indianapolis, IN
www.warrenrobotics.org
2008 Boilermaker Regional J&J Gracious Professionalism Award
2008 Bloomington Vex Champion
2007 St. Louis Regional Champion
Unread 03-01-2008, 15:20
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Usually com 3 or higher is the USB-to-Serial Adapter.
Unread 03-01-2008, 15:36
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Sounds like you have selected the wrong COM port. You need to find out what COM port has been assigned to that adapter.
Win XP: Control Panel>System>Hardware?(might be wrong)>Device Manager>Ports(COM and LPT)
OR
Vista: Control Panel>Device Manager>Ports(COM an LPT)
You should see one or more devices. Usually USB adapters have the word USB in their names. After the device name, in parenthesis, is the port number. Enter that in EasyC, and you should be good.
NOTE: If you plug the adapter into another USB port it will get a different port number.
Eric Haskins KC9JVH
Unread 03-01-2008, 19:37
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Did you hit the PROG button on the bot? You need to press and hold that until the light turns orange (NOT on the cable... but on the RC itself.)
Jacob
Unread 03-01-2008, 21:31
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
are you programming a vex or FRC and is it set up to that controller?
edit: also try controller verification in the download window and make sure it matches the controller you are programming
ALWAYS a mechanical problem!
Last edited by rhoads2234 : 03-01-2008 at 21:33. Reason: I added more reasons why it might not work
Unread 06-01-2008, 16:49
FRC #1691
Thank you all for your advice so far, i don't have access to the robot today, but i will get back with the results of trying these things probably tomorrow.
EasyC EDU BOT support? Chris_Elston Programming 11 07-06-2007 16:16
Major problems transfering code to RC agrahimi Programming 7 19-01-2007 23:08
EasyC Program For Camera? G1279 Programming 1 08-01-2007 19:00
Program 2005 robot with EasyC? scottmso Programming 4 02-02-2006 09:27
Calling C functions from EasyC koenig3456 Programming 4 27-01-2006 16:03
