Go to Post We haven't yet been able to find the A-team, but if we do... well, I pity the fool. :) - Madison [more]
  #91   Spotlight this post!
Unread 03-01-2008, 19:28
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: New C18 3.0+ Compatible FRC Code
Kevin,
While we're looking at the new code, what is the difference between interrupts 1,2 and 3-6? I read the encoders readme, and I understand how they differ. However, I haven't seen any documentation about the interrupts themselves. Could you please explain me how (if it all) they differ?
  #92   Spotlight this post!
Unread 03-01-2008, 21:33
Originally Posted by sumadin View Post
Kevin,
Digital inputs 1 and 2 each go to separate interrupt circuits. They can be configured to cause an interrupt on either a low-to-high or high-to-low transition of the input. The interrupt service routine can inspect individual flags to determine which input caused the interrupt.
Digital inputs 3-6 all go together to a third interrupt circuit, and automatically cause an interrupt on any input transition. There's only one flag to say that "something changed" on those pins. In order to determine which of the four inputs is responsible, the software has to do its own bookkeeping to compare the previous input state against the present one.
That's a simple explanation. There's more detail in the PIC manual if you want it.
  #93   Spotlight this post!
Unread 03-01-2008, 21:45
This makes sense. Thank you. I'll try using some of them soon, hopefully the ISRs in Kevin's code work as-is and then the difference won't really matter to me.
  #94   Spotlight this post!
Unread 04-01-2008, 03:31
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Code Monkey View Post
Last year we got an updated adc code which only used 1 interrupt per sample, instead of 2. Is this already implemented in the new adc code?
This evening I integrated a modified version of the ADC and gyro code into the new RC code and it seems to be very solid (while doing other things, including a bunch of printf()s, I have the ADC sampling at 6400Hz with no problems). The new ADC code uses the 8722s acquisition delay feature, which allows me to run it at one interrupt per sample, instead of two. I should be able to release it tomorrow.
Also last year we had to use a new processor .h file for the encoders. I see the encoder work is in progress, so this will also disappear, I hope?
This is next on my list.
-Kevin
Kevin Watson
http://kevin.org
  #95   Spotlight this post!
Unread 04-01-2008, 09:53
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Thanks for the link to Microchip. I went there three times and couldn't find it. The page looked like a sales page so I didn't scroll down and see the download links. Oh well. I've got it now.
  #96   Spotlight this post!
Unread 04-01-2008, 11:00
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Originally Posted by Kevin Watson View Post
..... I should be able to release it tomorrow.
-Kevin
Thank you Kevin for all of your hard work! I like what I see so far and I can assure you that team 34 will put this to good use.
Ed Sparks
MECH TECH FRC-3959
  #97   Spotlight this post!
Unread 04-01-2008, 11:11
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Kevin:
Here are some change that I made to your serial routine to set the baudrate correctly for any processor speed.
in serial_port.c
#ifdef ENABLE_SERIAL_PORT_ONE
void Init_Serial_Port_One(void)
// Start by initializing the serial port with code
// common to receive and transmit functions
// SPBRG = BAUD_38400 ; // baud rate generator register [251]
SPBRG = SPBRG_VAL_1; // defined in hardware.h
#ifdef USART1_USE_BRGH_LOW
TXSTAbits.BRGH = 0; // high baud rate select bit (asynchronous mode only) [248]
#else // 0: low speed
TXSTAbits.BRGH = 1; // high baud rate select bit (asynchronous mode only) [248] // 1: high speed
#endif // 1: high speed
#ifdef ENABLE_SERIAL_PORT_TWO
void Init_Serial_Port_Two(void)
// SPBRG2 = BAUD_9600; // baud rate generator register [251]
SPBRG2 = SPBRG_VAL_2; // defined in hardware.h
#ifdef USART2_USE_BRGH_LOW
TXSTA2bits.BRGH = 0; // high baud rate select bit (asynchronous mode only) [248]
TXSTA2bits.BRGH = 1; // high baud rate select bit (asynchronous mode only) [248] // 1: high speed
in the hardware set up routines...
// Define system xtal/clock frequency
#define CLOCK_FREQ (40000000) // Frequency in Hz
#if defined(__18CXX) // All PIC18 processors
#include <p18cxxx.h>
#define INSTR_FREQ (CLOCK_FREQ/4) // PIC18 clock divider
#else
#error Unknown processor or processor not defined
#endif
// Set up serial port(s) baud rate
#define BAUD_RATE_1 (38400) // Serial port 1, bps
#define BAUD_RATE_2 (38400) // Serial Port 2, bps
// set as needed...
//#define USART1_USE_BRGH_LOW // for most lower baud rates
//#define USART2_USE_BRGH_LOW // for most lower baud rates
#if defined(USART1_USE_BRGH_LOW)
#define SPBRG_VAL_1 ( ((CLOCK_FREQ/BAUD_RATE_1)/64) - 1)
#else
#define SPBRG_VAL_1 ( ((CLOCK_FREQ/BAUD_RATE_1)/16) - 1)
#endif
#if defined(USART2_USE_BRGH_LOW)
#define SPBRG_VAL_2 ( ((CLOCK_FREQ/BAUD_RATE_2)/64) - 1)
#else
#define SPBRG_VAL_2 ( ((CLOCK_FREQ/BAUD_RATE_2)/16) - 1)
#endif
#if ((SPBRG_VAL_1 > 255) || (SPBRG_VAL_2 > 255))
#error "Calculated SPBRG value is out of range for current CLOCK_FREQ."
#endif
  #98   Spotlight this post!
Unread 04-01-2008, 14:19
Code Monkey Code Monkey is offline
FRC #1622
Code Monkey is an unknown quantity at this point
Talking Re: New C18 3.0+ Compatible FRC Code
To be clear, without Kevin this would be miserable. Team 1622 is massively
in your debt. Thank you.
For those who have not already installed the MCC upgrade, make sure you put it in the same directory with the upgraded MPLAB 8.0. Otherwise the linker can't find the libraries. I know by the trying it the wrong way.
  #99   Spotlight this post!
Unread 04-01-2008, 19:23
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Rookie team 2605 will be using your code, it is structured in a way that makes more sense, I have not gone through it all the way yet, but so far so good. BTW is there a better search tool in mplab than the just straight basic find? For my embedded systems work I am always using grep and regexps, so far mplab has been really disappointing.
  #100   Spotlight this post!
Unread 04-01-2008, 21:16
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Comphappy,
The answer maybe Yes!
Try under the Project Menu > Find in Project Files.
Once you enter your keyword you'll be able to see the results in the output window under the find in files tab.
Double click on whatever you want to see and a new window will open with a pointer to your chosen element.
I hope this answers your question, as I'm not really sure as to what grep would deliver as a result.
  #101   Spotlight this post!
Unread 04-01-2008, 22:01
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Thanks that is what I was looking for, still not very good, but better then what I had found. Grep is extreamly flexible long as you are willing to spend the time to learn how to use it correctly.
  #102   Spotlight this post!
Unread 04-01-2008, 22:22
FRC #2429
Here's a snapshot of the latest build:
http://kevin.org/frc/ifi_frc_beta_3.zip
http://kevin.org/frc/ifi_frc_gyro_beta.zip (with integrated ADC and Gyro code)
-Kevin
Kevin Watson
http://kevin.org
  #103   Spotlight this post!
Unread 04-01-2008, 22:33
Kevin,
Is there any change log? So we can keep track of what's bew in beta 3? Other than, of course, the ADC and gyro in that version.
Thanks.
  #104   Spotlight this post!
Unread 05-01-2008, 00:03
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I know MPLAB can generate a makefile for you but those always seem messy so I wrote up a quick one to use for myself with Kevin's new code. Figured I'd share it here in case anyone else finds it useful.
# Makefile for Kevin Watson's (http://kevin.org) C18 3.0 compatible FRC code
CC = C:\\mcc18\\bin\\mcc18.exe
CFLAGS = -p=18F8722 -k -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
LD = C:\\mcc18\\bin\\mplink.exe
LDFLAGS = 18f8722.lkr
LIBS = ifi_frc_8722.lib
LIBPATH = C:\\mcc18\\lib
MAP = ifi_frc.map
RM = del
SOURCES = autonomous.c disabled.c ifi_code.c ifi_frc.c interrupts.c pwm.c \
          serial_ports.c teleop.c timers.c
OBJECTS = $(SOURCES:.c=.o)
EXECUTABLE = ifi_frc
all: $(SOURCES) $(EXECUTABLE)
$(EXECUTABLE): $(OBJECTS)
	$(LD) /l"$(LIBPATH)" $(LDFLAGS) $(OBJECTS) $(LIBS) /m"$(MAP)" /w /o"$(EXECUTABLE).cof"
.c.o:
	$(CC) $< -fo="$@" $(CFLAGS)
clean:
	$(RM) $(OBJECTS) $(EXECUTABLE).cof $(EXECUTABLE).hex $(MAP)
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Last edited by jtdowney : 05-01-2008 at 08:05. Reason: mp2hex is ran automatically by the linker so it isn't needed
  #105   Spotlight this post!
Unread 05-01-2008, 18:57
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Forgive my noobiness, but is that makefile what I need to develop on ubuntu? Set up c18 in wine, put the file in the directory with the code and do a make? Will that give me a loadable hex file? There was another makefile posted earlier that looked like it was made for Linux, should I use that?
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
