Go to Post If a kid was in FIRST and no one was around to see it, do they still get inspired? - Katie_UPS [more]
Go Back   Chief Delphi > Other > VEX
Unread 03-01-2008, 22:45
charlie1218 charlie1218 is offline
FRC #1218
charlie1218 will become famous soon enoughcharlie1218 will become famous soon enough
Re: Vex Flame finding
BTW these are not just the line sensors, but those photoelectric sensor modules aswell.
Unread 04-01-2008, 13:59
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Remember, no non VEX KOP (kit of parts). We have 2 flame sensors btw
I figured if it was an event that had flames that there would be some level of slack from the "ONLY VEX KOP" rule.
1)Take the nut driver tube and cut the narrow end off. This will leave you with the wide end that just covers the sensor and about 2" of focus tube. At $4.99 each, this is not a cheap solution.
2)Take the rubber mat and wrap four turns around a 1/2" dowel. You are trying to get the little nubs to fit into the mesh. Secure with the black zips.
3)Take two or three intake rollers and using the black zips make them into a tube. Drill a 3/8" hole in the center.
Mounting is up to you.
Post a picture of what you finally do.
Unread 04-01-2008, 15:04
FRC #1218
NO slack, only KOP
Unread 04-01-2008, 15:17
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
set up the 2 light sensors at the rough level of the candle and as far away from eachother as the dimesions allow. The 2 senors should face slightly inward if possible
Compare the readings of the 2 sensors and give more power to the motor on the same side as the reading with more light (I believe that lower #s are bright light but I am not sure)
This should center you on the candle - Put in code to stop when you cross the white pad around the candle otherwise you will run right into the candle
I recommend trying to narrow the range of vision for the sensors. If you can only use KOP see if a couple lock plates (without the center piece which actually put the axle through) gives you a wide enough range... I think that hole in the bearing flats is a little too narrow.
Tell me if it Works! and good Luck!
ALWAYS a mechanical problem!
Unread 04-01-2008, 15:18
rhoads2234's Avatar
AKA: Erin
FRC #2234
Originally Posted by charlie1218 View Post
NO slack, only KOP
do you mean you can't even modify the parts? ouch!
Unread 04-01-2008, 23:28
FRC #1218
We cant cut, twist and do whatever, but we cannot add pieces.
Flame Warriors! Andrew Blair Chit-Chat 1 05-10-2006 14:17
Finding range DanDon Programming 11 10-01-2006 22:58
Finding color brownster Programming 1 20-02-2005 03:23
Finding sponsorship Lisa Perez Team Organization 12 17-10-2004 16:43
Finding new teams Kit Gerhart Finding A Team 8 13-04-2004 12:05
