Go to Post A FIRST fanatic who never had any desire to be an engineer. There. I said it. ;) - Katie Reynolds [more]
Unread 04-01-2008, 11:11
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Re: New C18 3.0+ Compatible FRC Code
Kevin:
Here are some change that I made to your serial routine to set the baudrate correctly for any processor speed.
in serial_port.c
#ifdef ENABLE_SERIAL_PORT_ONE
void Init_Serial_Port_One(void)
// Start by initializing the serial port with code
// common to receive and transmit functions
// SPBRG = BAUD_38400 ; // baud rate generator register [251]
SPBRG = SPBRG_VAL_1; // defined in hardware.h
#ifdef USART1_USE_BRGH_LOW
TXSTAbits.BRGH = 0; // high baud rate select bit (asynchronous mode only) [248]
#else // 0: low speed
TXSTAbits.BRGH = 1; // high baud rate select bit (asynchronous mode only) [248] // 1: high speed
#endif // 1: high speed
#ifdef ENABLE_SERIAL_PORT_TWO
void Init_Serial_Port_Two(void)
// SPBRG2 = BAUD_9600; // baud rate generator register [251]
SPBRG2 = SPBRG_VAL_2; // defined in hardware.h
#ifdef USART2_USE_BRGH_LOW
TXSTA2bits.BRGH = 0; // high baud rate select bit (asynchronous mode only) [248]
TXSTA2bits.BRGH = 1; // high baud rate select bit (asynchronous mode only) [248] // 1: high speed
in the hardware set up routines...
// Define system xtal/clock frequency
#define CLOCK_FREQ (40000000) // Frequency in Hz
#if defined(__18CXX) // All PIC18 processors
#include <p18cxxx.h>
#define INSTR_FREQ (CLOCK_FREQ/4) // PIC18 clock divider
#else
#error Unknown processor or processor not defined
#endif
// Set up serial port(s) baud rate
#define BAUD_RATE_1 (38400) // Serial port 1, bps
#define BAUD_RATE_2 (38400) // Serial Port 2, bps
// set as needed...
//#define USART1_USE_BRGH_LOW // for most lower baud rates
//#define USART2_USE_BRGH_LOW // for most lower baud rates
#if defined(USART1_USE_BRGH_LOW)
#define SPBRG_VAL_1 ( ((CLOCK_FREQ/BAUD_RATE_1)/64) - 1)
#else
#define SPBRG_VAL_1 ( ((CLOCK_FREQ/BAUD_RATE_1)/16) - 1)
#endif
#if defined(USART2_USE_BRGH_LOW)
#define SPBRG_VAL_2 ( ((CLOCK_FREQ/BAUD_RATE_2)/64) - 1)
#else
#define SPBRG_VAL_2 ( ((CLOCK_FREQ/BAUD_RATE_2)/16) - 1)
#endif
#if ((SPBRG_VAL_1 > 255) || (SPBRG_VAL_2 > 255))
#error "Calculated SPBRG value is out of range for current CLOCK_FREQ."
#endif
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
