Go to Post We don't just build robots. We build people. - Koko Ed [more]
Unread 04-01-2008, 19:56
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Inventor into .pdf
Came across an interesting question at work today. Is it possible to take an file in Inventor and EASILY change it to a .png file? We have the Acrobat Pro to create .pdf files from Word files.
Currently, I'm taking .pdf files of parts, using the selection tool to grab what I need, then pasting it into a new Photoshop file, then saving it as a .png to insert into the Word file to convert into the .pdf file for the shop floor.
Most of the planners are capable of learning new programs, but generally don't have the time required to put into the learning. Hence, we need to know if we can do the same thing between Inventor and the Word file in one extra step.
Two last notes on the issue:
1. Using the Print Screen function loses a great deal of the detail in the drawing.
2. Importing the images into the Word document takes up too much disk space. (I've saved things as .png that were .jpg and brought a file from 100Mb down to 1.5Mb.)
Thanks,
indieFan
Unread 04-01-2008, 20:28
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Inventor into .pdf
Well, why don't you just print as pdf through inventor using something like
PDFCreator
Much easier than going through the long convoluted process of converting to a word document.
Unread 04-01-2008, 21:07
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
depending on what you are needing to render as images, you can switch into inventor studio mode and render a picture, there is a whole set of tutorials on doing this at www.autodesk.com/FIRSTbase
Unread 04-01-2008, 22:10
FRC #5941
Is Inventor Studio a part of Inventor or is it part of a software suite?
To answer why we don't just print a .pdf through something like PDFCreator: We are a large company. As such, there are strict guidelines to follow regarding what software we can and cannot use. FOSS (Free & Open Source Software) is not allowed. Paying for another program to do the same job as Acrobat Pro makes no sense, either.
To explain what we're doing a little more:
I write planning (instructions) for operators on the shop floor to follow. The planning is written in Word using a template to easily add, remove, or modify an operation in the future when the instructions change. To create useful planning, images are inserted into each operation.
Images are created by opening the .pdf of the part drawing, using the selection tool, and then put into Photoshop where I can erase lines and arrows that make the drawing difficult to understand. Or, I'll add color only to those portions of the part that are being dealt with at the time.
indieFan
Unread 05-01-2008, 00:07
AKA: Brennan Ashton
FRC #2605 (A2D_16)
indieFan
That better have a real good explanation, cus FOSS keeps alot of the world spinning, Apache anyone?
Apache web server 49.57%
Microsoft IIS 35.76%
Back to the question at hand, yes it is part of the suite. I cannot tell you if it was installed or not by your obviously blind IT department.
Oh and guess what I would recommend that you stop using google, there servers run linux.
Unread 06-01-2008, 15:57
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
When an Inventor file is open, you can go to File>Save Copy As and choose BMP, JPG, GIF, PNG, or TIFF.
(The "Save" dialog is different from "Save Copy As" dialog. Only the latter has file type options.)
In a drawing file, you can change the colors of different lines; in parts, change the color of a single surface by right-clicking on the surface and selecting "Properties".
Inventor Studio is part of Inventor; it's under the Applications menu in a part or assembly file. It's made to render images for presentation, so it might not be useful for the shop.
I know you said you don't want to use new software, but I recommend looking into Autodesk Design Review.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 07-01-2008, 13:58
FRC #5941
Thanks for the information Dan. This is exactly the sort of thing we're looking for. I think I'll pass on Inventor Studio if I can do it all with Inventor alone. Now I just need to remind the professor to let me borrow the team's copy so I can tinker with it at home. ;-)
Thanks again,
indieFan
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Embossing Text Into Parts with Inventor Andrew Blair Inventor 4 30-10-2005 12:47
Importing Inventor Into 3ds max? Jeremiah Johnson 3D Animation and Competition 8 31-01-2005 21:30
Need to import robot made in inventor into 3dsmax, HELP! anish 3D Animation and Competition 1 03-03-2002 13:53
Importing Inventor Assemblies into 3dsMAX cyanutopia 3D Animation and Competition 1 25-02-2002 12:22
