Go to Post Your attribute of personal sacrifice is very noble, but FIRST needs YOU to be successful first. - DanKein [more]
Unread 05-01-2008, 01:12
FRC #0701 (RoboVikes)
Re: How does division work?
Originally Posted by comphappy View Post
If you need the extra places the most efficient way to do it will be to bit shift the dividend, and remember that any time you need to do a calculation, you need to bit shift the result back. using bit shift instead of multiplying by something like 10 will save you a few clock cycles.
multiplication 8-bit by 8-bit method (if you multiply by an arbitrary value such as 10)
see here http://www.dcc.unicamp.br/~celio/mc4...los/mul8x8.asm
Program Memory : 14 locations
# of cycles : 71
RAM : 5 locations
That is a really big waist
bit shift method
c equivalent
x<<1;
can be done with the single asm command lrol (load and rotate left)
I would warn against using this for the reasons outlined before (granted it *should* work)...
The key reason being that you as a programmer really shouldn't have to worry about things like that as it is the compilers problem. Most compilers are written so that operations are optimized (for special cases like the one above).
Unless you are writing hardware drivers you don't need to worry about assembly level optimization. Even hardware shaders (which are run directly on graphics cards) are now written in a C-like language rather than in assembly like before.
Team 701
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
