Go to Post I am always torn between running a family and running a team... I guess the difficulty is in supporting the team as a whole before the individual...or alongside the individual. - MysterE [more]
Unread 05-01-2008, 01:33
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Re: Downloading from laptops
I now have one of my laptops working and I'll try getting the others to work tomorrow.
I noticed that programs that were smaller than 0x8000 would download correctly while larger ones would not.
I also noticed that the IFI loader that ran on the desktop machines would print out that they were Erasing banks 1-8 but the laptop machines did not. The printed out a message that said it was erasing memory but nothing about bank numbers.
I found in the ifiloader directory in Program Files an INI file. This file has a variable called debug_level that was set to 0. I thought that I might get some insight if I raised this level so I edited the INI file to set the debug_level to 1
As soon as I did this, the loader started printing out the messages about erasing banks 1-8 and now larger executables download successfully. I was curious if this variable was set on my desktop machines. It is not set.
I went back to the laptop and changed the INI file back to its original state. The IFIloader still works!. I appears that changing the INI file somehow fixed the problem but changing it back does not cause the problem to reappear. IFIloader might write something into the registry but I couldn't find anything.
As I said, I'll try doing the same trick to the other laptops and see if that magically fixes things.
HP Laptops Beth Sweet Chit-Chat 23 28-05-2006 20:53
Downloading Video from a Camcorder woes Ian Curtis Chit-Chat 4 14-09-2005 21:13
Laptops Mike Chit-Chat 23 30-05-2005 19:52
Problem Downloading from Streamline petek Inventor 2 10-03-2005 21:07
