Go to Post I (personally) am not involved in FIRST because I want to win (of course, that would still be nice ;) ). - pogenwurst [more]
Unread 05-01-2008, 12:59
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
Robot Design
our team has been discussing a forklift design that will lift up the ball over, the overpass.
What do you think guys?
any ideas would be helpful it seems like an easy happy medium
for stability and you still get the 8 points
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 05-01-2008, 13:00
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
wilmo will become famous soon enough
Re: Robot Design
two words: height limit
Unread 05-01-2008, 13:02
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Robot Design
Yeah, if anybody has any ideas for decent designs, please do share.
Also: Major lack of good defense = lame.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 05-01-2008, 13:06
"Wilfordito"
Re: Robot Design
Yeah, height limit is the issue but there should something to let the forklift be able to function even without a large height that would still be able to propel the trackball over.
Unread 05-01-2008, 14:00
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Robot Design
What height limit?
-Dustin Benedict
Unread 05-01-2008, 14:01
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
Re: Robot Design
yeah, after the game starts its an Infinate height limit.
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 05-01-2008, 14:03
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Robot Design
Re: Height limit.
I posted this in the main game thread: A sphere supported by rails 32" apart would still dangle far enough below the rails to be accessible by robots limited to 6ft tall. The bottom of the ball would be 5'10" off the ground, I think.
given a trackball center at (0,0)
given a trackball contact point with a rail at (16,y) (the rails are 32" apart)
given the trackball is 20" and assuming it remains approximately spherical, then...
x^2 + y^2 = r^2
16^2 + y^2 = 400
y^2 = 400 - 256
y = 12
So the contact point for the rails will be 12" below the center of the ball. This means that between the rails, the bottom of the ball should be 8" below them, and thus 2" below the maximum allowed height of a robot in the opponent zone. However, this is in an ideal world where the rails are infinitely thin and the ball is perfectly sperical. Since the rails are 1.5" wide and the ball will deform some, the ball may be slightly higher (or lower if it deforms a lot) than where I computed it to be, and the contact space for a robot will be small.
Obviously this is an easy test to run and I'm sure somebody will post their real-world results soon.
Unread 05-01-2008, 14:09
tanmaker
Posts: n/a
Re: Robot Design
The only height constraint is 60 inches, a.k.a. 5 feet. That is at the starting position ONLY. There is no height constraint for the duration of the game. just make sure you're lower than 6.5 feet while you drive under the overpass
Unread 05-01-2008, 14:13
Bongle's Avatar
Re: Robot Design
Rule G36 sayeth:
HOME STRETCH Height Restriction – ROBOTS in the HOME STRETCH of the opposing
ALLIANCE can not be more than 6 feet tall. A PENALTY will be assigned for each
infraction.
Unread 05-01-2008, 14:16
tanmaker
Posts: n/a
Re: Robot Design
Originally Posted by Bongle View Post
Rule G36 sayeth:
infraction.
I guess we were both correct. So on your own half of the field, the is no height restriction, but everywhere else, it's 6 feet
Unread 06-01-2008, 19:08
FRC1710's Avatar
FRC1710 FRC1710 is offline
FRC #1710
FRC1710 is an unknown quantity at this point
Re: Robot Design
In the competition "fake game" with the people in the carts they would extend the ball OVER the middle divider, MAKING them over 6 feet to get it over the center bar. This means the home stretch is only one section of the 4 quarters of the field. I don't believe that height will be much of a problem then, however, I do find it silly that you are only restricted height-wise in that one 27x13 ft area.
Unread 06-01-2008, 20:27
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: Robot Design
This has probably been posted at least thirty times but... The home stretch is indeed the quadrant immediately preceeding the appropriate alliance's finish line. Also, you could use a two stage lift, but I'm not sure you want to do that.
Unread 06-01-2008, 20:31
Mike@1023 Mike@1023 is offline
Rookie
AKA: Michael Cononie
FRC #1023 (Bedford Express)
Team Role: Student
Mike@1023 is an unknown quantity at this point
Send a message via AIM to Mike@1023
Re: Robot Design
Re: Height limit.
x^2 + y^2 = r^2
16^2 + y^2 = 400
y^2 = 400 - 256
y = 12
thats much too complicated. we just made an overpass mock-up and measured. you were correct. 8 inches. 5 minutes tops our way though, and no headache...
My Team. 1023.
We're on year 6 and still doing great!
(And expect to continue to do great!)
Wish us luck in '08!
2007 Bedford Express Rookie, Build Team Member
2007 - GLR & Boilermaker Finalists & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award
2004 - GLR/DTR Semi Finalist
2003 - GLR Quarter Finalist & GLR/NAT'L Rookie All Star
Robot Design adventrx327 General Forum 8 12-03-2004 21:25
Legal Robot Design? adventrx327 General Forum 10 09-03-2004 22:50
progress of robot design rcubes85 General Forum 9 14-02-2003 13:00
SPAM Robot design GateRunner Rumor Mill 29 19-01-2003 00:34
Team 131 'C.H.A.O.S.' robot design archiver 1999 0 23-06-2002 22:37
