How does descoring work?
I must not be understanding this correctly... can someone help shed some light?
Re: How does descoring work?
Seems you drive past the home stretch, turn around, and either grab it or knock it off from there. Sucks...
edit: thinking. I'll prob come back to this thread. |
Based on <G22>, I'm pretty sure that that's not a legal alternative.
You could knock the ball down with a blast of air. If your robot is six feet tall, it's only six inches to the overpass.
edit: And you can be on the finish line in the wrong direction, just not CROSS it, from how <G22> reads to me. |
The ball weighs about 10 lbs, so a blast of air from six inches away is going to be tough.
I assume the ball is nested in the bridge, therefore the bottom might be below the 6' limit. This might allow you to punch the ball off. Thoughts? |
#7
So you could go past the overpass, then turn around and knock the ball off...
Besides, G22 says "by moving", not by turning. <G22> Direction Of Traffic ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction. |
#8
I agree w/ the ball hanging idea, any way to calculate how low it hangs?
#9
But to jgannon, you can turn around and knock it down. 7.2 Definition of crossing You're considered crossing when ALL PARTS have crossed the line. GO past, turn around, don't fully cross the line, you're fine and dandy. |
#10
No! What you describe would not be considered crossing, but it would certainly be breaking the plane. Remember, "Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction." Any motion that caused you to break the plane of that line from there would have to be clockwise in nature.
#11
We measured about 70 inches from the bottom of the ball the floor, at the kickoff.
#13
Is that measurement, or were you able to calculate that? If it was calculation, I would really like to know how for future reference.
#14
Another thought though -- what if they intended for it to be a penalized process? If you want to get your second ball into play, you have to gamble the points? |
#15
If so, the human demonstration didn't show it.
| How does division work? | JBotAlan | Programming | 14 | 09-01-2008 10:58 |
| How does it work? | Ryan O | Control System | 5 | 12-03-2006 19:15 |
| How does Nationals work? | coldfusion1279 | Championship Event | 29 | 30-03-2005 16:47 |
| How Does a Winch Work? | Aaron Lussier | Technical Discussion | 23 | 20-01-2004 21:14 |
| How does Nationals work?? | LunchBox | Championship Event | 16 | 18-03-2003 15:55 |
