Go to Post This is how students can be inspired! - Rich Wong [more]
Unread 06-09-2001, 00:42
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
2001 Drive Motors
I'm sure this question has already been asked a few times but i'm kinda curious. I know that last year my team, Team #64 the Gila Monsters used the drill motors with 4x4 direct drive, and we had a heck of a time trying to drag the goals around. I know it's because the way we had our robot geared, we had plenty of speed but no tourque.
So i know teams like #45, who's robots i really liked by the way, and the cheesy poofs had no problem double balancing everytime. I was wondering which motors you used and how you geared them to get that kind of tourque? this question is directed at all teams by the way.
Unread 06-09-2001, 08:17
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
45
Look under the white pages for our entire drive assembly prints...that should be some help...
EDIT:
2001 Dual Motor Switching Assy
2000 Gear Switching And Motor Mount Assy
(I'll leave it to Andy to tell all the specs, if he gets around to it)
Purdue Alumni
Cummins, Inc.
Unread 06-09-2001, 10:28
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Hi-Torque and Good Speed
Team 535 used two drill motors (one per side) with associated transmission. We had one motor driving two wheels using a chain. On the output shaft of the drill motor we attached an 18 tooth gear and at the wheels we had a 60 tooth gear.
During testing we tried 12, 14, 16 and 18 tooth output gears and found the 18 tooth was the best for speed and torque.
We were able to pull the goals or the stretcher with absolutely no problem.
We also had the speed to auto-balance on the bridge with one or two goals securred to our robot.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 06-09-2001, 21:17
Matt Reiland's Avatar
'The' drive behind the drive
Dont forget to factor in Wheel Size and Traction Level when considering just the gearing. When we increased our traction by a large amount we started breaking drivetrain components since the old system had more slip that was easier on the system
Unread 07-09-2001, 08:12
AKA: Warthog
Oops
Sorry, forgot to mention the wheels we used.
We used the 8" wheelchair wheels that we grooved with a soldering iron with a "V" groove tip.
Major traction. Also if the grooves start to disappear you can go over them again with the iron. We ran a full season with just one set of tires.
Wayne Doenges
Unread 07-09-2001, 16:15
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
Team 151 used a direct drive van door motor set up. We went for all torque and little speed. The gamble proved good at The UTC regional where we were the only team to successfully pull a fully loaded stretcher, and we seeded our way into the finals at a respectable 8 out of 51. However the gamble didn't pay off at nationals where we couldn't achieve high enough scores (due to no time multipliers) to run with the "big dogs" and seeded a respectable 48 out of 81 in the Acrhimedies division, and didn't make the finals. Once again however our high torque proved very useful at BattleCry at WPI where we were able to "steal" goals from some teams due to our high power.
We have already decided that more speed is essential next year.
On the drill motor front I know some teams who used them this year did very well in the traction department, because their grabbing mechanism transferred the weight of the goal onto their drive-train thus putting more weight on their wheels giving them better traction. For example I know the killer bees (33) and Tesla (95) used this approach.
Chris Team 151
http://team151.tripod.com
Unread 07-09-2001, 16:24
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
It's been a few months since I've seen our robot, but from memory.... We used the bosch drill motors in low gear, and then from there we had a reduction (that I forget at the moment) to the small wheelchair wheels.
Unread 07-09-2001, 17:24
Jason Morrella Jason Morrella is offline
Robotics Education and Competition
AKA: J-Mo
no team (RECF)
Jason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond repute
Hey there GilaHumanPlayer
We also use the drill motors for 4 wheel drive. There two main reasons we had no problems with pulling the goals or traction on the bridge.
1. We were able to switch gears, so once we had both goals and/or got to the bridge - we would switch to low gear.
2. The real key was that we used the pnematics to pick up one end of one goal - which transferred the weight to the robot and made it much easier to pull up the bridge.
The other team you mentioned, #45 the TechnoKats, had a different system. They also switch gears, but their big advantage was that they used the drill motors AND fisher price motors in tandem. Basically attaching the motors together - making the robot either faster without giving up much power, or more power without giving up much speed depending on the gear they were in. Very cool innovation on their part - which we are experimenting with ourselves over the summer.
Off the topic - do you know where the GilaMonsters are going to compete in 2002. I know you normally do 2 regionals, with LA being your home event. We might not go to LA this year, so we're hoping you guys (64) might compete at the Silicon Valley again. Partners in the National playoffs in 99 & 2000, and regional competitors (qualifying partners) all three years at regionals - it just won't feel right if we don't see team 64 at a regional!!!!
Tell Chris & Mike I said hi.
Unread 09-09-2001, 14:56
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Weight is also an inportaint part in being able to balnce and push things around.
Greg
Unread 09-09-2001, 17:13
We also used these really cool threads instead of wheels for our robot
Purdue Alumni
Cummins, Inc.
Unread 10-09-2001, 00:55
It's a Bird
AKA: BoogyShoes
Gila Mosters Regionals
Sorry its off subject but the question was asked by team 254 where we (64) were going this year. We really haven't set anything in stone but as far as we can see the LA regional thanks to team 22 will be the biggest next year so we hope to compete there again. And obviously we would like to return the virginia regiongal this year due to our success last year. Really hope to see team 254 in action before nationals. Hope everything works out with you guys this year, and know that the Gilas love the Cheesy Poofs. And I would also like to compliment you to the greatest extent for your excelent robot and driver in the 2001 season and all seasons before, and it was a shame we couldn't have taken it all in 2000.
Unread 10-09-2001, 07:57
We have used the drill motors for drive train for several robots now. These motors have some very strict limitations and production differences (like speed variance from motor to motor and forward to reverse) but if consideration is give to correct gearing, speed and torque can be optimized very well. The same can be said for the the Fisher Price motors which we have also used this year as boost motors for four wheel drive when needed. Please note that motors should not be expected to work for heavy loads at low RPM. Extended use in this way WILL cause overheating and eventual failure. Check the data sheets, they are your friend.
Unread 28-09-2001, 21:43
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Cool
Well,
We here at #5 used our drill motors with the shifters they came with. At first, we grinded. Really, really bad. Than we made it go very, very slowely when it shifted, to catch the gears, and we where fine! And as for the wheels, we used tank-tracks! Just some timing belts with some "dead-wheels" under-neath, non-moving. (For all the ppl that are mad of the wording, sorry, i kan't spel!)
That rug really tied the room together...
Unread 29-09-2001, 08:16
I had a chance to see your robot and the shifter was a good idea. You obviously overcame the problem with shifting. What did you use to accomplish the shift?
Unread 29-09-2001, 16:57
AKA: Maher Attallah
It was home-made. As soon as i can get a pic of it, i will post it here!
How many motors are you using to drive? Joseph F Motors 18 16-10-2002 21:24
2001 Scratch Awards Andy Grady General Forum 12 04-10-2001 22:04
