Go to Post Build a robot that isn't 119.999999 lbs - Peyton Yeung [more]
Unread 05-01-2008, 14:10
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
How does descoring work?
I must not be understanding this correctly... can someone help shed some light?
<G36> HOME STRETCH Height Restriction – ROBOTS in the HOME STRETCH of the opposing ALLIANCE can not be more than 6 feet tall. A PENALTY will be assigned for each infraction.
<G22> Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
How do you ever get your ball down from the overpass overlooking your opponent's finish line? You can't even reach the overpass when you're in the opponent's home stretch, and because the edge of the overpass is aligned with the finish line, you aren't allowed to reach to the overpass once you're out of the home stretch. Do you just have to hope that your opponents don't wait until the end to knock your ball down? In the end game, can you not score on your opponent's side? Can you not descore on your opponent's side?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-01-2008, 14:45
LordTalps LordTalps is offline
Crimson Ninja
AKA: Pat
FRC #1885 (Robocats)
LordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to behold
Send a message via AIM to LordTalps
Re: How does descoring work?
Seems you drive past the home stretch, turn around, and either grab it or knock it off from there. Sucks...
edit: thinking. I'll prob come back to this thread.
I will not leave my account logged on to chiefdelphi again.
Unread 05-01-2008, 14:46
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Based on <G22>, I'm pretty sure that that's not a legal alternative.
_
Unread 05-01-2008, 14:57
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
You could knock the ball down with a blast of air. If your robot is six feet tall, it's only six inches to the overpass.
Unread 05-01-2008, 15:01
Crimson Ninja
AKA: Pat
You can go in any direction in a given quadrant, you just can't cross the lines going the wrong direction. Otherwise if a ball rolled into a corner, you're in extremely hot water.
edit: And you can be on the finish line in the wrong direction, just not CROSS it, from how <G22> reads to me.
Unread 05-01-2008, 15:02
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
The ball weighs about 10 lbs, so a blast of air from six inches away is going to be tough.
I assume the ball is nested in the bridge, therefore the bottom might be below the 6' limit. This might allow you to punch the ball off. Thoughts?
Scott5736 (formerly Scott3137(formerly Scott358))
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
So you could go past the overpass, then turn around and knock the ball off...
Besides, G22 says "by moving", not by turning.
Unread 05-01-2008, 15:03
AKA: Anthony
I agree w/ the ball hanging idea, any way to calculate how low it hangs?
Unread 05-01-2008, 15:12
Crimson Ninja
AKA: Pat
Getting my math out, brb.
But to jgannon, you can turn around and knock it down.
7.2 Definition of crossing
You're considered crossing when ALL PARTS have crossed the line. GO past, turn around, don't fully cross the line, you're fine and dandy.
Unread 05-01-2008, 15:16
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
No! What you describe would not be considered crossing, but it would certainly be breaking the plane. Remember, "Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction." Any motion that caused you to break the plane of that line from there would have to be clockwise in nature.
_
Unread 05-01-2008, 15:19
AKA: Anthony
The key word here is "moving." Wouldn't pivoting be allowed? You could at lest pivot counter-clockwise if that is where the problem lies.
Unread 05-01-2008, 15:20
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
We measured about 70 inches from the bottom of the ball the floor, at the kickoff.
Unread 05-01-2008, 15:24
AKA: Anthony
Is that measurement, or were you able to calculate that? If it was calculation, I would really like to know how for future reference.
Unread 05-01-2008, 15:28
Crimson Ninja
AKA: Pat
Hope you're not getting too worked up, just thinking in a lot of directions and not spent a lot of time arond the rules. You're definitely right there. We might be limited to the bottom of the ball, going to figure out how low it hangs in a second.
Another thought though -- what if they intended for it to be a penalized process? If you want to get your second ball into play, you have to gamble the points?
Unread 05-01-2008, 15:35
AKA: Anthony
If so, the human demonstration didn't show it.
How does division work? JBotAlan Programming 14 09-01-2008 10:58
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
