Go to Post They can build a robot in 6 hours, so they don't need to start meeting for months... - Karthik [more]
Unread 05-01-2008, 14:57
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
Re: How does descoring work?
You could knock the ball down with a blast of air. If your robot is six feet tall, it's only six inches to the overpass.
Unread 05-01-2008, 15:02
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
The ball weighs about 10 lbs, so a blast of air from six inches away is going to be tough.
I assume the ball is nested in the bridge, therefore the bottom might be below the 6' limit. This might allow you to punch the ball off. Thoughts?
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 05-01-2008, 15:12
LordTalps LordTalps is offline
Crimson Ninja
AKA: Pat
FRC #1885 (Robocats)
LordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to behold
Send a message via AIM to LordTalps
Getting my math out, brb.
But to jgannon, you can turn around and knock it down.
7.2 Definition of crossing
You're considered crossing when ALL PARTS have crossed the line. GO past, turn around, don't fully cross the line, you're fine and dandy.
I will not leave my account logged on to chiefdelphi again.
Unread 05-01-2008, 15:16
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
No! What you describe would not be considered crossing, but it would certainly be breaking the plane. Remember, "Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction." Any motion that caused you to break the plane of that line from there would have to be clockwise in nature.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-01-2008, 15:19
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
The key word here is "moving." Wouldn't pivoting be allowed? You could at lest pivot counter-clockwise if that is where the problem lies.
Unread 05-01-2008, 15:28
Crimson Ninja
AKA: Pat
Hope you're not getting too worked up, just thinking in a lot of directions and not spent a lot of time arond the rules. You're definitely right there. We might be limited to the bottom of the ball, going to figure out how low it hangs in a second.
Another thought though -- what if they intended for it to be a penalized process? If you want to get your second ball into play, you have to gamble the points?
Unread 05-01-2008, 15:35
AKA: Anthony
If so, the human demonstration didn't show it.
Unread 05-01-2008, 15:38
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Use another ball to descore a ball?
Edit: As seen in the Arena rules, the Home stretches are only a quarter of the field each. Go past your opponents finish line and you're free to return to >6' height. You can stop and drive around in a given quarter of the field, as long as you don't go back across a line.
Unread 05-01-2008, 15:53
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
You cannot be over 6' high in your opponent's home stretch, so you must go under the overpass in order to reach high enough to descore the ball. BUT, when you go under the overpass, you cannot touch the ball because you would then break the plane of the opponent's finishline, causing you to recieve a penalty.
This seems like a vicious circle to me.
Unread 05-01-2008, 16:06
AKA: Anthony
Well, we have about 2 inches of space that the ball will hang down below the plane. Still, two inches is not a lot of space...
Unread 05-01-2008, 16:23
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
It's good to see that there is potentially a way to legally descore. In any case, I'm really hoping that this isn't the intent of these rules. As a referee, it's going to be insanely difficult to tell if a robot was at 72" or 73" when it knocked out the ball.
_
Unread 05-01-2008, 16:25
Crimson Ninja
AKA: Pat
Yep. There's some guesswork in the case, and you'd have to be very hopeful the ref didn't decide to penalize you just for coming close to the height limit. That or have some very good evidence that you didn't/can't.
Unread 05-01-2008, 16:34
skrew-ball skrew-ball is offline
None #0975
skrew-ball will become famous soon enough
ok, my team is here discussing this. would the risk of a penalty at end game be worth it? a 10 point penalty and a 12 or 24 point denial. The height penalty is also done by the break of the height plane, not the time out of it. So you could extend out, knock off the 2 balls and drive around in the opposing lane, preventing any future occurance. -10 on you, -?? on them minimum of -12 on them. Thus giving you a minimum of a 2 point advantage, increasing in 12 point increments.
Also, couldn't you score more than 10 points to offset the penalty?
Unread 05-01-2008, 16:52
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
There was some discussion about this idea last year... if it was worth it to interfere in the opponent's home zone, take a couple penalties, but keep the opponent from lifting. The general consensus was that intentionally taking penalties would be a yellow-cardable offense. I don't necessarily agree with this (I like the idea of fouling to stop the clock in basketball, or taking a delay-of-game in football to give your punter more room to kick), but that seems to be the prevailing opinion. However, this year there is only one instance of a yellow card being mentioned in the manual, and no explanation of how the card system works, so it's hard to say if there will actually be yellow cards. Maybe intentional penalties will be acceptable this year?
_
Unread 05-01-2008, 16:56
None #0975
So at this point I assume it is ok
p.s. others, the yellow card is for not moving when bumped
after 6 seconds
How does division work? JBotAlan Programming 14 09-01-2008 10:58
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
