Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 05-01-2008, 14:45
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Post Can you knock a ball out of a opponents hold...
Can you knock a ball out of an opponents hold while they are try to hurdle it?
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 05-01-2008, 14:54
Caseavong's Avatar
Caseavong Caseavong is offline
The Karaoke Champ!
AKA: Casey Viriyavong
FRC #0191 (X-cats)
Caseavong is a jewel in the roughCaseavong is a jewel in the roughCaseavong is a jewel in the rough
Send a message via AIM to Caseavong
Re: Can you knock a ball out of a opponents hold...
<G42> Protection While HURDLING – A ROBOT in the process of HURDLING shall not be
subjected to overt, blatant, or aggressive contact that interferes with the HURDLING
attempt. Each incident will be PENALIZED. Bumping to signal to pass (see Rule <G38>) a
HURDLING ROBOT is permitted if no passing lane is open (see Rule <G43>). Incidental
contact while passing the HURDLING ROBOT or otherwise engaged in normal game play is
permitted.
<G43> IMPEDING With Multiple HURDLERS- If multiple ROBOTS are HURDLING simultaneously
and effectively blocking the width of the TRACK, then opposing ROBOTS may signal to
pass and the HURDLING ROBOT must clear a passing lane within 6 seconds. A PENALTY
will be awarded to the HURDLING ROBOT for each violation.
-Passion builds a robot-
Im asian
Unread 05-01-2008, 14:56
Caseavong's Avatar
The Karaoke Champ!
FRC #0191 (X-cats)
Personally i think,
you can't intentially knock out the opponents trackball while they are attempting to hurdle it
Im asian
Unread 05-01-2008, 15:05
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
how bout when they are trying to put the ball on top of the overpass, I would guess some rules apply
Team 842 Programmer
Pictures at:
Videos -
Unread 05-01-2008, 15:10
Caseavong's Avatar
The Karaoke Champ!
FRC #0191 (X-cats)
Yeah, because that would be considered Hurdling the ball.
Im asian
Unread 05-01-2008, 19:02
teamchallenger teamchallenger is offline
FRC #2047
teamchallenger is an unknown quantity at this point
The proper answer to this question is YES DEPENDING. You can not overtly knock the ball while hurdling. But sideswiping while passing would be OK.
When NOT in the act of hurdling, you could bash the ball away from the opponent. Knocking an opponents ball out of the ring would be a valid strategy as long as you only did it once during a match.
Unread 20-01-2008, 14:25
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
Based on the update (#2, I think), the Trackball cannot be knocked out while a robot is trying to Hurdle or place it without the knock-outer earning a penalty.
However, there are no rules against this at any other period of the game.
How Long Can You Hold Your BREATH? Yan Wang Chit-Chat 62 03-03-2009 19:33
can u add a new member to the top 10 kids if you take one out? Miller VEX 2 16-11-2006 10:10
How can you figure out robot speed?!?! gnirts Programming 7 01-04-2006 13:05
how do you hold pins in? archiver 2001 4 23-06-2002 23:45
