Re: How does descoring work?
Another thought though -- what if they intended for it to be a penalized process? If you want to get your second ball into play, you have to gamble the points? |
If so, the human demonstration didn't show it.
Use another ball to descore a ball?
![]() Edit: As seen in the Arena rules, the Home stretches are only a quarter of the field each. Go past your opponents finish line and you're free to return to >6' height. You can stop and drive around in a given quarter of the field, as long as you don't go back across a line. Last edited by Gertlex : 01-05-2008 at 03:43 PM. |
You cannot be over 6' high in your opponent's home stretch, so you must go under the overpass in order to reach high enough to descore the ball. BUT, when you go under the overpass, you cannot touch the ball because you would then break the plane of the opponent's finishline, causing you to recieve a penalty.
This seems like a vicious circle to me. |
It's good to see that there is potentially a way to legally descore. In any case, I'm really hoping that this isn't the intent of these rules. As a referee, it's going to be insanely difficult to tell if a robot was at 72" or 73" when it knocked out the ball.
#7
Yep. There's some guesswork in the case, and you'd have to be very hopeful the ref didn't decide to penalize you just for coming close to the height limit. That or have some very good evidence that you didn't/can't.
#8
ok, my team is here discussing this. would the risk of a penalty at end game be worth it? a 10 point penalty and a 12 or 24 point denial. The height penalty is also done by the break of the height plane, not the time out of it. So you could extend out, knock off the 2 balls and drive around in the opposing lane, preventing any future occurance. -10 on you, -?? on them minimum of -12 on them. Thus giving you a minimum of a 2 point advantage, increasing in 12 point increments.
Also, couldn't you score more than 10 points to offset the penalty? |
#9
So at this point I assume it is ok
p.s. others, the yellow card is for not moving when bumped after 6 seconds |
#11
It's a lot of point counting, unless the rules somehow get changed or opened up for more interpretation.
#12
Yeah, one of the speakers on the Kickoff broadcast said the the refs were in for a rough time. The refs have to go through an actual course and tests before they can actually referee.
#13
I was more thinking on a strategic side but yes, the refs are in for trouble XP
#14
So the rules state that
<G36> HOME STRETCH Height Restriction – ROBOTS in the HOME STRETCH of the opposing ALLIANCE can not be more than 6 feet tall. A PENALTY will be assigned for each infraction. In the video of the HUMAN PLAYERS, the blue alliance was passing a ball over the lane divider. Though the lane divider is 6ft tall, stretching to get the ball over the top seems to be pushing it. Is that okay to do? Just sit there and wait for a ball to come your way? On that note, I know there have been six zillion threads on this, but it has been decided that pushing a Trackball off of the other side of the overhand during any mode would be considered illegal, correct? |
#15
| How does division work? | JBotAlan | Programming | 14 | 01-09-2008 10:58 AM |
| How does it work? | Ryan O | Control System | 5 | 03-12-2006 07:15 PM |
| How does Nationals work? | coldfusion1279 | Championship Event | 29 | 03-30-2005 04:47 PM |
| How Does a Winch Work? | Aaron Lussier | Technical Discussion | 23 | 01-20-2004 09:14 PM |
| How does Nationals work?? | LunchBox | Championship Event | 16 | 03-18-2003 03:55 PM |
