Go to Post the point is that FIRST is successful, in so many different ways - Pamela [more]
Unread 05-01-2008, 15:38
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Re: How does descoring work?
Use another ball to descore a ball?
Edit: As seen in the Arena rules, the Home stretches are only a quarter of the field each. Go past your opponents finish line and you're free to return to >6' height. You can stop and drive around in a given quarter of the field, as long as you don't go back across a line.
Unread 05-01-2008, 15:40
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Originally Posted by Ragnarokae View Post
Is that measurement, or were you able to calculate that? If it was calculation, I would really like to know how for future reference.
Posted this in a couple other threads today.
given a trackball center at (0,0)
given a trackball contact point with a rail at (16,y) (the rails are 32" apart)
given the trackball is 20" and assuming it remains approximately spherical, then...
x^2 + y^2 = r^2
16^2 + y^2 = 400
y^2 = 400 - 256
y = 12
So the contact point for the rails will be 12" below the center of the ball. This means that between the rails, the bottom of the ball should be 8" below them, and thus 2" below the maximum allowed height of a robot in the opponent zone. However, this is in an ideal world where the rails are infinitely thin and the ball is perfectly sperical. Since the rails are 1.5" wide and the ball will deform some, the ball may be slightly higher than where I computed it to be, and the contact space for a robot will be very, very small.
Glad to hear someone did the actual measurement and it was close
Here's a diagram:
http://www.chiefdelphi.com/forums/at...4&d=1199558995
Unread 05-01-2008, 15:43
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
We measured that at the kickoff.
But it is possible to figure it out. The overpass bars are 32 inches apart.(the arena 6.2.2) The balls are 40" in diameter.(the game piece 6.3) And the overpass is 78 inches high.
I'll let you do the math.
Unread 05-01-2008, 15:44
LordTalps LordTalps is offline
Crimson Ninja
AKA: Pat
FRC #1885 (Robocats)
LordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to behold
Send a message via AIM to LordTalps
Circular relationship, err, function for a circle. X^2 + Y^2 = R^2
Radius of ball -- 20"
length of overpass -- 32", believedly.
16^2 + y^2 = 20^2
y = 12. 12 is the height from the center of the sphere to the overpass.
20 - 12 = 8" the ball dips down at maximum, giving us only 2" of impact room to play with.
edit: b10. bleh.
I will not leave my account logged on to chiefdelphi again.
Unread 05-01-2008, 15:49
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
Here is a link to another thread with a math proof regarding the height of the ball on the overpass. http://www.chiefdelphi.com/forums/sh...t=60666&page=4
We have approx. 2 in or less to work with...
Unread 05-01-2008, 15:51
AKA: Anthony
Sorry everyone, I forgot to hit refresh, and thus missed LordTalps' post.
Unread 05-01-2008, 15:53
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
You cannot be over 6' high in your opponent's home stretch, so you must go under the overpass in order to reach high enough to descore the ball. BUT, when you go under the overpass, you cannot touch the ball because you would then break the plane of the opponent's finishline, causing you to recieve a penalty.
This seems like a vicious circle to me.
Unread 05-01-2008, 16:06
AKA: Anthony
Well, we have about 2 inches of space that the ball will hang down below the plane. Still, two inches is not a lot of space...
Unread 05-01-2008, 16:23
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
It's good to see that there is potentially a way to legally descore. In any case, I'm really hoping that this isn't the intent of these rules. As a referee, it's going to be insanely difficult to tell if a robot was at 72" or 73" when it knocked out the ball.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-01-2008, 16:25
Crimson Ninja
AKA: Pat
Yep. There's some guesswork in the case, and you'd have to be very hopeful the ref didn't decide to penalize you just for coming close to the height limit. That or have some very good evidence that you didn't/can't.
Unread 05-01-2008, 16:34
skrew-ball skrew-ball is offline
None #0975
skrew-ball will become famous soon enough
ok, my team is here discussing this. would the risk of a penalty at end game be worth it? a 10 point penalty and a 12 or 24 point denial. The height penalty is also done by the break of the height plane, not the time out of it. So you could extend out, knock off the 2 balls and drive around in the opposing lane, preventing any future occurance. -10 on you, -?? on them minimum of -12 on them. Thus giving you a minimum of a 2 point advantage, increasing in 12 point increments.
Also, couldn't you score more than 10 points to offset the penalty?
Unread 05-01-2008, 16:52
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
There was some discussion about this idea last year... if it was worth it to interfere in the opponent's home zone, take a couple penalties, but keep the opponent from lifting. The general consensus was that intentionally taking penalties would be a yellow-cardable offense. I don't necessarily agree with this (I like the idea of fouling to stop the clock in basketball, or taking a delay-of-game in football to give your punter more room to kick), but that seems to be the prevailing opinion. However, this year there is only one instance of a yellow card being mentioned in the manual, and no explanation of how the card system works, so it's hard to say if there will actually be yellow cards. Maybe intentional penalties will be acceptable this year?
_
Unread 05-01-2008, 16:56
None #0975
So at this point I assume it is ok
p.s. others, the yellow card is for not moving when bumped
after 6 seconds
Unread 05-01-2008, 17:08
Crimson Ninja
AKA: Pat
It's a lot of point counting, unless the rules somehow get changed or opened up for more interpretation.
Unread 05-01-2008, 17:14
AKA: Anthony
Yeah, one of the speakers on the Kickoff broadcast said the the refs were in for a rough time. The refs have to go through an actual course and tests before they can actually referee.
How does division work? JBotAlan Programming 14 09-01-2008 10:58
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
