Go to Post guys, don't forget not to scare the new girls - Lisa Rodriguez [more]
Unread 05-01-2008, 15:05
Caseavong's Avatar
Caseavong Caseavong is offline
The Karaoke Champ!
AKA: Casey Viriyavong
FRC #0191 (X-cats)
Caseavong is a jewel in the roughCaseavong is a jewel in the roughCaseavong is a jewel in the rough
Send a message via AIM to Caseavong
How long can you stay Stationary?
How long is a robot able to stay stationary with getting a penalty?
-Passion builds a robot-
Im asian
Unread 05-01-2008, 15:08
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: How long can you stay Stationary?
There is no stated limit for the amount of time that a robot is allowed to stay stationary. However, there are several restrictions on where your robot is allowed to be under certain circumstances, and the time limit you have to rectify a violation. See <G40>-<G43>. Basically, it all depends on where you are and what your opponents are doing, but presumably if you're off sitting in a corner, you would be permitted to stay there for the entirety of the match if you so desired.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-01-2008, 15:11
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I think what Casey is asking about is what happened at the end of the demo when one robot stopped at the other side of the finish line and bounced the ball back to their alliance partner on the other side so they could place the ball up top at the end. Are you allowed to stop and bounce the ball back to your partner like that and if you are how long or how often?
Unread 05-01-2008, 15:22
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
EDIT: Got this wrong the first time. If you are HURDLING, you are also CROSSING at the same time. As such, I'm thinking that you would get eight points for the first HURDLE, and six for each HURDLE after being tipped back. That doesn't sound right at all, but that's the best I can read from this. The only way I can make the seemingly proper interpretation happen (where only the first one counts) is if scoring by HURDLING is dependent on scoring by CROSSING.
<G13> A TRACKBALL that has CROSSED its own FINISH LINE must CROSS the opponent’s FINISH LINE before it can score by CROSSING its own FINISH LINE again.
_
Unread 05-01-2008, 15:34
Caseavong's Avatar
The Karaoke Champ!
FRC #0191 (X-cats)
Sorry to say this but wow that sound more confusing then helpful.
A trackball has to cross the opponets finish line before you can score again...
I thought it had to only pass the yellow line; that seperates each overpass.
Im asian
Unread 05-01-2008, 15:52
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
as I far as I can tell, in the video, when the bal was bounced back, it didn't hurdle, it was placed on top, so it didn't need to cross the opponent line (I may be wrong but that's how I see it)
Unread 05-01-2008, 17:46
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I asked Mr. Brown (National Head Ref) about this and he said that as long as the robot is not IMPEDING progress (per definition), then the robot does not have to move. ie, unless there is no clear path around robot, the robot does not have to move
Unread 05-01-2008, 19:27
reflion reflion is offline
Design Team 2204
FRC #2204 (Rambots)
reflion is an unknown quantity at this point
Remember, though, if another robot bumps you for impeding, you must clear the path. So if you're just trying to be obnoxious by being a roadblock, it won't work.
How Long Can You Hold Your BREATH? Yan Wang Chit-Chat 62 03-03-2009 19:33
How long do you keep the warranty valid? Billfred Chit-Chat 2 07-08-2006 22:59
How long does it take you to recover? sanddrag Chit-Chat 16 02-03-2005 02:01
How long can car idle on a tank of gas? sanddrag Chit-Chat 11 13-09-2004 12:46
How many hotels did you team stay at?? Elgin Clock Championship Event 4 10-05-2002 17:53
