Go to Post The answer the last 3 years would be any regional that 1114 attends. - Cory [more]
Unread 05-01-2008, 17:33
Dick Linn's Avatar
no team (Synergy)
Re: Gear Manual
This is pretty good (from U.S. Tsubaki). It's only on-line (no PDF), but you might be able to request a copy from them: http://chain-guide.com/toc.html
There is some gear engineering reference info near the back of this Boston Gear catalog: http://www.bostongear.com/litportal/...%20PAGESsm.pdf
If you want reference material on gearing, power transmission or general mechanics and machining, try searching on one of those terms in Google Books. The trick is to then do an advanced search and select FULL VIEW. That will get you all the old books that are out of copyright, and you can download them. I've found dozens of great books. Not a whole lot has happened to gearing over the last 80 years or so that would apply to our robots, except we've all but forgotten how to make the big ones and the machinery to do it. If you don't believe me, go to this link, and scroll through ALL the pictures - the gears are toward the bottom.
http://www.practicalmachinist.com/vb...d.php?t=148241
Hare's a book that might be useful: http://books.google.com/books?id=T-k...sms&as_br r=1
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
ME reference manual Gdeaver Technical Discussion 10 06-12-2005 12:42
Consolidated Manual! Nate Smith General Forum 2 08-03-2003 18:48
Manual Johca_Gaorl General Forum 1 06-01-2003 17:29
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
low gear vs high gear archiver 2000 1 23-06-2002 23:07
