| Thread Tools |
Rating:
Display Modes |
#46
Re: 2008 game confusion thread
Yes
#47
so the fact that you can only have 4 commmands isnt limited by the rules it is just limited by the controller, so if you have one command toggle to another set of commmands, that is ok?
#48
A question about the IR thingy.
Is it possible to have one of the 4 cahnnels swith different modes, for example, switch between arm control and drive control, and those making the other 3 buttons do a different thing in each of those modes? |
#49
FIRST im confused on why Dean said that "Overdrive isn't a hint" when it was the game......WHAT COULD THIS MEAN....HAVE THEY ALL BECOME AS MISCHIEVIOUS AS DAVE?!?!?!?!
lol2-A robot cannot be over 6' in an opponents home stretch so then how is one to play defense by removing balls or to even more important put balls into play?? can you sit behind the finish and reach back in...that would put your bot over 6' in the opponents home stretch....HELP!?!?!?! |
#50
Having a "mode switch" plus three other buttons would qualify as six "states" and, thus, is illegal. Additionally, having a multi-button sequence is also illegal. However, I think having one button do two things is allowed as long as it can be described as one thing and the robot autonomously decides which of the two to do, for example, arm toggle. See also http://www.chiefdelphi.com/forums/sh...ad.php?t=60694 |
#52
Also, as I just added to the first post, the youtube video clearly shows a red robot above the overpass in the blue home stretch!
Youtube Still Frame Last edited by neutrino15 : 05-01-2008 at 18:46. |
#53
Hey all, I had a question regarding breaking the plane lines of the four quadrants. What if a robot crashes into your robot and the only way fo ryou to get out is to back up over a line? Is this still a penatly you aren't doing it to gain an advantage.
#54
The other robot has 6 seconds to move before he's disqualified or receives a penalty, so you just wait it out.
#55
Joey Edit: Here is the rule <G23> Causing PENALTIES - A ROBOT’s action shall not cause an opposing ROBOT to break a rule and thus incur penalties. Any rule violations committed by the affected ROBOT shall be excused, and no penalties will be assigned. For example, an opposing ROBOT may not be pushed into another ROBOT in an attempt to cause a IMPEDING situation and violation of Rule <G40> by the opponent, nor may a TRACKBALL be placed intentionally on an opposing ROBOT for the purpose of causing the opponent to violate Rule <G26>. Last edited by Laaba 80 : 05-01-2008 at 19:02. |
#56
Is it possible to have a string of commands from a controller meaning different things?
i.e. #1,#2,#of ft to drive forward - Drive Forward #1,#3,#position to move arm to (three set positions on the y-axis) |
#59
No, you can't.
Well, technically, you can, but you'll be disqualified. |
#60
It's because you can only have a maximum of four commands.
| 2008 Game Thread | Rick TYler | Rumor Mill | 17 | 30-05-2009 22:58 |
| [Official 2008 Game Design] Game Elements and Subtasks | dlavery | FRC Game Design | 35 | 25-05-2008 22:37 |
| [Official 2008 Game Design] OK, so YOU design the 2008 game... | dlavery | FRC Game Design | 25 | 20-02-2008 23:31 |
| 2008 Game- Overdrive | Chant_358 | General Forum | 155 | 06-01-2008 19:00 |
| 2008 FIRST game | vivek16 | General Forum | 86 | 04-12-2007 09:23 |
