Go to Post Everybody "cares about the robots" - otherwise we'd be doing science fairs. - Taylor [more]
Unread 05-01-2008, 20:57
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Re: Robocoach signals loophole?
Of course! That's why you can use four buttons.
Unread 05-01-2008, 20:59
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
I'm guessing as long as you only use four buttons, which you can press in any order, and all act independently, you should be okay. If each button could execute some random program, you culd do whatever you wanted.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 05-01-2008, 21:03
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Cool Re: Robocoach signals loophole?
I hope so! This will lead to a very interesting discussion at our meeting...
This could make the hybrid mode a fun time this year.
Unread 05-01-2008, 21:43
Matthew2c4u's Avatar
Matthew2c4u Matthew2c4u is offline
AKA: Matt Baker
FRC #1622 (Spyder)
Team Role: Tactician
Matthew2c4u has a spectacular aura aboutMatthew2c4u has a spectacular aura about
Send a message via AIM to Matthew2c4u Send a message via MSN to Matthew2c4u
<G01> HYBRID PERIOD - The HYBRID PERIOD is the 15-second period at the start of the
MATCH. Driver control of the ROBOT is not permitted at this time. During this period, the
ROBOTS may react only to sensor inputs and commands programmed into the onboard
control system. The only external signals that may be received by the ROBOT are those
sent from ALLIANCE ROBOCOACHES. No external signals are permitted from any other
source. The ROBOT may react to no more than four distinct external commands provided by
the ROBOCOACH. All ROBOT safety rules are still applicable during the HYBRID PERIOD.
The HYBRID PERIOD ends when the arena timer displays zero seconds left in the period.
It looks to me that this means your entire alliance can send commands to your robot Think of the possibility if theres 12 commands
Unread 05-01-2008, 21:59
davidfv davidfv is offline
FRC #0399 (Eagle Robotics)
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
I am thinking how much time would you have to program each of the remotes to your robots? Once we start playing with the IR and programming it, we can see how easy it can be programmed.
Davidfv
Mentor/Drive Coach
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I believe this is against the spirit of the rules, and therefore I will not be pursuing it. However,
What is stop you from treating one of the buttons as an enter button? For instance, say you are using 1, 2, 3, and 4. In that case, you could press 1, then 2 then 4 (enter), and the robot would do whatever "12" tells it to. This gives you 9 combinations. Or, if you'd like the robot just to pause for 2 seconds while you enter it and get rid of the "enter" button, you could have sequences like 1-3-2-4-2.
Take that a step further and pick up a programmable remote with LCD screen from radio shack. These allow a single button press to send out multiple signals. You could program one to completely control your robot.
Again - I'm not pursuing this. But it is something we discussed until we decided it was against the spirit of what First meant the rule to mean.
Unread 05-01-2008, 22:04
AKA: Matt Baker
FRC #1622 (Spyder)
This is illegal Via <G01> and <R69> which state only four commands, and no changing the set of 4 avalible
Unread 05-01-2008, 22:48
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
<R65> & <R69> in Section 8 of the manual gives a really go overview of what the SIGNALING DEVICE can be and what it CAN and CAN NOT do. I think everyone should go back and give it a nice good read, it should clear up a lot of questions.
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
Unread 05-01-2008, 23:37
ericbarch's Avatar
ericbarch ericbarch is offline
221 Robotic Systems Engineer
FRC #0027 (Team Rush)
ericbarch is a jewel in the roughericbarch is a jewel in the roughericbarch is a jewel in the roughericbarch is a jewel in the rough
Send a message via AIM to ericbarch
Does this put limits on state changes? For example...could 1 button be used to start and stop the action? What about holding down the button instead of just tapping it? Would this count as a separate command? It seems like this is a gray area at the moment.
Unread 05-01-2008, 23:52
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
excerpt from <R65>
communicate no more than four messages, states or conditions to the ROBOT (please refer to Rule <R69> and Rule <G01> for additional information) during any single MATCH.
<R69>
meet all of the following criteria:
• For a single MATCH, the ROBOT shall be limited to react to a maximum of four distinct commands - either through hardware or software limitations, or a combination of the two.
• The ROBOT shall not dynamically change the recognized command set during a MATCH.
• The ROBOT may only seek out and react to permitted SIGNALING DEVICES belonging to the assigned ALLIANCE (as defined in Rule <R65>). Intentionally reacting to other SIGNALING DEVICES is prohibited.
MATCH. Driver control of the ROBOT is not permitted at this time. During this period, the ROBOTS may react only to sensor inputs and commands programmed into the onboard control system. The only external signals that may be received by the ROBOT are those sent from ALLIANCE ROBOCOACHES. No external signals are permitted from any other source. The ROBOT may react to no more than four distinct external commands provided by the ROBOCOACH. All ROBOT safety rules are still applicable during the HYBRID PERIOD. The HYBRID PERIOD ends when the arena timer displays zero seconds left in the period.
I believe that it is pretty apparent that the GDC wants us to use the four commands as just that -- commands. I interpret the rules stating that any sort of command to do any one thing is permitted (eg. drive straight; turn left; or an entire autonomous mode), so that the buttons could be used to select a list of commands, however complex those commands are. However, I believe that any sort of stepping command, or combinations of buttons are not permitted.
http://www.wcsrobotics.com
team 663
team 1493
Unread 06-01-2008, 01:50
Using the rules quoted above:
You may have FOUR buttons (any four) set to trigger FOUR routines. From Dave's example of the Mars rover, they can tell it to "investigate this rock and then come back". That can involve multiple actions.
Your 3"x5" card is to say what routines the robot will run if the right buttons are used.
My impression follows; I find nothing against this: You may as usual have multiple auto programs. Each may have a different set of routines. If this is the case, I'd advise you to have multiple cards, labeled on one side for the mode.
Unread 06-01-2008, 01:53
ErikSR71's Avatar
ErikSR71 ErikSR71 is offline
FRC #1138
ErikSR71 is on a distinguished road
This potential loop-hole is blocked in section 8 <R65>. "signaling devices shall... communicate no more than four messages, states or conditions to the ROBOT" A signal sent by pressing multiple buttons would be a 5th message, and any action 5th action would be a 5th state or condition. There is no loop-hole with this rule.
Unread 06-01-2008, 02:37
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
We're using an Apple remote. It has the typical circle of four buttons with one in the middle.
Top: Increment speed (both motors)
Bottom: Decrement speed
Right: Increment right motor speed (for turning)
Left: Decrement right motor speed
Is that legal?
What place are we at? ... TODAI!
Unread 06-01-2008, 02:44
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
yeah but aren't there controls that have programmable buttons?
cant you just say this button
but that button would include a series of programed keys
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 06-01-2008, 09:43
PookAir PookAir is offline
AKA: Chuck Shnitzel
FRC #1577 (Steampunk)
PookAir is an unknown quantity at this point
This is not true you robot can only recive 4 diffrent encodings so all the teams can send your robot orders but there will only be 4
Robotics Hand Signals JulieB Chit-Chat 21 19-06-2005 00:11
PWM Signals stevex Programming 1 28-10-2004 18:03
IR signals inverted Atheist Electrical 10 08-02-2004 16:27
Autonomous user-input loophole? Jeff McCune Programming 20 14-02-2003 22:44
Referee hand signals archiver 1999 1 23-06-2002 21:57
