Go to Post FIRST is all about helping eachother and team work, isn't it? - vadyr [more]
Unread 05-01-2008, 21:59
davidfv davidfv is offline
FRC #0399 (Eagle Robotics)
Team Role: Tactician
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
Re: Robocoach signals loophole?
Originally Posted by Matthew2c4u View Post
<G01> HYBRID PERIOD - The HYBRID PERIOD is the 15-second period at the start of the
MATCH. Driver control of the ROBOT is not permitted at this time. During this period, the
ROBOTS may react only to sensor inputs and commands programmed into the onboard
control system. The only external signals that may be received by the ROBOT are those
sent from ALLIANCE ROBOCOACHES. No external signals are permitted from any other
source. The ROBOT may react to no more than four distinct external commands provided by
the ROBOCOACH. All ROBOT safety rules are still applicable during the HYBRID PERIOD.
The HYBRID PERIOD ends when the arena timer displays zero seconds left in the period.
It looks to me that this means your entire alliance can send commands to your robot Think of the possibility if theres 12 commands
I am thinking how much time would you have to program each of the remotes to your robots? Once we start playing with the IR and programming it, we can see how easy it can be programmed.
Davidfv
Mentor/Drive Coach
Robotics Hand Signals JulieB Chit-Chat 21 19-06-2005 00:11
PWM Signals stevex Programming 1 28-10-2004 18:03
IR signals inverted Atheist Electrical 10 08-02-2004 16:27
Autonomous user-input loophole? Jeff McCune Programming 20 14-02-2003 22:44
Referee hand signals archiver 1999 1 23-06-2002 21:57
