Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Unread 05-01-2008, 22:14
COACHTJ1688's Avatar
COACHTJ1688 COACHTJ1688 is offline
-STICKSHIFT ROBOTICS-
AKA: TJ
FRC #1688 (Stickshift)
COACHTJ1688 is an unknown quantity at this point
BENCH POWER SUPPLY - Help!
I wanted to be able to work with the control system at my home so I recently purchased a radio shack bench power supply model # 22-510.
It ranges from 12-13.8 volts and its 25 amps. It is switched but not variable amperage output.
Will I blow up the RC if I use this for power while testing?
If so, any suggestions on us9ing a switched power supply? Is there any way to rig up a voltage regulator...or an amperage regulator, perhaps a dimmer switch?
I can't find any specs on the battery itself. I don't have one inf rom of me and I'm guessing at model numbers on the mk battery site.
"If you can't fix it with duct tape...you haven't used enough duct tape."
Unread 05-01-2008, 22:34
AKA: TJ
Re: BENCH POWER SUPPLY - Help!
Looking deeper into some other posts I've found that the RC has an internal regulator?
Can anyone confirm this?
Unread 05-01-2008, 22:36
HotWings HotWings is offline
AKA: Jon
FRC #0548 (Robostangs)
Team Role: Webmaster
HotWings is on a distinguished road
You'll be absolutely fine! When you charge the batteries from the Kit, they sometimes go as high as 14.7volts! I am our teams electrical captain, and i permit you to continue with your work
Unread 05-01-2008, 22:37
AKA: TJ
I'm worried about amperage. The output is 25 amps.
Unread 05-01-2008, 22:39
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Welcome to Chief Delphi first. Second of all, your question is one of caution, and thats good. Don't want to fry anything. That is a very powerful power supply, a bit overkill for the controllor. The input voltage is 12 volts (ideally - as a battery rated at 12 volts will actually have a voltage slightly higher when fully charged, and slightly lower when running out of juice). the power supply is rated at 25 amps (which is a good deal of power). So, if you needed to, you could draw that much current, however, there is no limit to how little current you can draw. Car batteries are often rated for very high amperage, for things like starting your car, but your radio works just fine from the same battery. I can't verify that there is a built in regulator onboard the controllor, although it would make sense. You know you can never assume though. I could be completely wrong, my coffee level is pegged at empty, and it's been a few years since digital electronics - but if it were me, I'de connect it. Just remember to connect first, then turn on power, otherwise you could get a spike in power...and that very well could fry it.
"Jack of all trades, master of none, though offtimes better than master of one".
AKA: Jon
Yes i know, It should be fine.. Amps at that level shouldn't really mean anything. And plus like you said i am 99% sure there is a built in regulator in the board. 1 sec though.
Unread 05-01-2008, 22:42
AKA: TJ
Thanks for the quick replies. This is my first foray into programming. I'm normally the welding/build guy.
I've seen my share of magic smoke released from electronics...and I'd rather not destroy a brand new RC if I can help it.
AKA: Jon
http://www.ifirobotics.com/docs/firs...up-charger.pdf
Theres the wiring diagram. Seems like its there to me
Like the other guy said, its only going to draw the amps it needs.
Unread 05-01-2008, 22:43
DonRotolo's Avatar
Back to humble
FRC #0832
Electrical circuits only use as much amperage as they need.
Water pressure is like voltage, while water flow rate is like current (Amperes).
If you turn on a faucet, it doesn't matter if the pipe behind it can supply a thousand gallons per second, the faucet will "use" what it uses. If, however, the pressure (voltage) gets too high, the faucet may burst - so keep the voltage below around 14 volts and you'll be fine. 25 Amps is the max, the circuit determines what it "uses".
Note: Switched power supplies need some load to regulate properly. be sure something is connected to it before switching it on. Maybe won't matter, but cheap insurance.
Good luck,
Don
Unread 05-01-2008, 22:44
AKA: TJ
I'll keep the receipt handy. HAHA.
Thanks for the help. I'll make sure to report my findings to either this forum, or the fire department...or both.
Unread 05-01-2008, 23:05
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
I'm not sure whats the quality of your PSU, but what I'd do on an unknown PSU (including those for computers):
1. Connect up voltmeter parallel to the 12v rails
2. Add a 12v load: maybe a 12v fan or two.
3. Fuse in series with your 12v line: I think 10A is more than enough?
4. A switch [S1] in series with your 12v line just BEFORE your control systems
So you turn on your psu first, but leave S1 off. Check the voltage and if you're happy, turn on S1. Reason being some switching PSUs start off with a voltage >>> 12V for a few milli/micro seconds immediately after turn-on and may fry your stuff. Just a precaution
| jamesyong.net |
FVC2007, FTC2008
Unread 05-01-2008, 23:54
Umm Errr...
It will be fine. The regulation circuitry is pretty robust. I've seen one of these things take a short spike of about 24v and live happily through the rest of a season. The power supply you mention should keep the RC comfortable.
1139 Alumni
Unread 05-01-2008, 23:57
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
The O/I can draw a max of 1000ma ((1amp) (i believe)) 25 amps i think is a bit much??
Unread 06-01-2008, 00:07
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
If you just need to power the RC, you might be able to save a few dollars and just use an old 12V wall wort transformer with some female spade connectors crimped on to it. The backup battery might even work when hooked up to the 12V terminals.
Unread 06-01-2008, 00:17
AKA: Jon
Not a good idea to me lol.
Circuit design help - power supply - Non FIRST Josh Siegel Electrical 31 24-12-2005 13:47
Power Supply evit General Forum 2 06-02-2003 08:59
