Go to Post Social life? Ha! Robotics is my social life. :D - Éowyn [more]
Unread 05-01-2008, 19:58
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Bumpers
Everyone seems to be discussing scoring and balls, and I didn't feel this fit anywhere so...
I've read through the majority of section 8, and it mentions the STARTING CONFIGURATION and the PLAYING CONFIGURATION but fails to say how bumpers apply to these.
What I mean is if I wanted to make a robot that tips over at the start to give me a larger base (as I know has been done in the past) in my starting configuration do I have to have bumpers covering 2/3 of the perimeter in the bumper zone, or does this only apply to the playing configuration(s)
This 2/3 also confused me, if we wanted to create a plow of some sort in the base to herd balls is this blow added to the perimeter.
If I normally have 38"+38"+28"+28", a simple rectangle, would mean 88" of bumpers, then would a rectangle with a 10" indent in the 38" with a length of 30" mean 38"+28"+28"+4"+10"+30"+10"+4" mean I'm forced to have 103" which isn't even possible if I only want to put bumpers on the 3 unindented sides (38+28+28=94 which is <103)?
Sorry if that was lengthy and confusing
Unread 05-01-2008, 20:12
daftpunk79's Avatar
daftpunk79 daftpunk79 is offline
AKA: Lizzy
no team (Bomb Squad)
daftpunk79 is on a distinguished road
Send a message via MSN to daftpunk79 Send a message via Yahoo to daftpunk79
Re: Bumpers
I'm not entirely sure, but I can almost bet you anything everything about the bumpers is going to be pretty much the same as last year, no one has said anything dif. about them here yet.......maybe I should ask......
Unread 05-01-2008, 22:42
Re: Bumpers
I found this, although I fail to see WHERE in <R08> it states how bumpers are affected
<G18> ROBOT Orientation - ROBOTS must start the MATCH with their long (maximum) dimension
in a vertical orientation. After the start of the MATCH, ROBOTS may change their orientation
such that the long dimension is either vertical or horizontal. Refer to Rule <R08> and Rule
<R17> to determine how this affects the use of STANDARD BUMPERS and FLAGS.
Unread 06-01-2008, 00:19
daftpunk79's Avatar
AKA: Lizzy
Re: Bumpers
STANDARD BUMPERS – Bumper assemblies designed to attach to the exterior of the ROBOT within
the BUMPER ZONE, and constructed as specified in Rule <R08>. STANDARD BUMPERS may weigh
up to 15 pounds, and are excluded from the weight and volume calculations specified in Rule <R11>.
is the only thing i could find on it....now im getting confused
Unread 06-01-2008, 01:38
Re: Bumpers
One thing to say--Q&A. It isn't covered, so ask.
Unread 06-01-2008, 01:43
daftpunk79's Avatar
AKA: Lizzy
Re: Bumpers
i keep thinking of that
Unread 06-01-2008, 01:47
lawdog69's Avatar
lawdog69 lawdog69 is offline
AKA: Bryan Reed
FRC #0234 (Cyber Blue 234)
lawdog69 is an unknown quantity at this point
Re: Bumpers
Just make sure your plow is not like a wedge. According to
<R19> "Wedge” ROBOTS are not be permitted. ROBOTS shall be designed so that interaction with opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage (e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the infraction.
I was thinking about making the same suggestion until reading this rule.
Bumpers? 1596guy Technical Discussion 2 10-02-2007 13:55
Bumpers great_one411 General Forum 1 05-02-2003 16:49
Bumpers archiver 2000 2 23-06-2002 22:48
Bumpers archiver 2000 0 23-06-2002 22:32
bumpers Martin Rules/Strategy 2 13-01-2002 21:51
