Go to Post Safe zones are for the weak. - ChristopherSD [more]
Unread 05-01-2008, 22:23
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Question Signed and unsigned variables
What is the proper method to cast from an unsigned to a signed variable?
For example, suppose that u is an unsigned int and i is a signed int.
When u is 0, i should be -32768.
When u is 32768, i should be 0.
When u is 65535, i should be 32767.
Which of the following is correct:
i = (unsigned int) u or
i = (unsigned int) (u - 32768)?
Thanks,
David
Unread 05-01-2008, 22:34
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Signed and unsigned variables
As a matter of form, neither is correct, although the second is closest to your requirements. Assuming you have defined 'u' as unsigned int, and 'i' as int, you use:
i = (int) (u - 32768);
Unread 05-01-2008, 22:40
MIT '14
Thanks!
-David
Unread 05-01-2008, 22:42
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
int main(int argc, char *argv[])
unsigned int u;
int i;
u = 0; // i should be -32768.
i = (unsigned int) u;
printf("%d %u\n",i , u);
i = (unsigned int) (u - 32768);
u = 32768; // i should be 0.
u=65535; // i should be 32767.
return 0;
0 0
-32768 0
32768 32768
0 32768
65535 65535
32767 65535
Your test case with output. Did that help?
Unread 05-01-2008, 23:03
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
My first attempt at this post did not address the problem ... so second attempt.
The only thing you need to be careful of is that casting is not a shift as it might seem intuitive to be. An unsigned char 0 is not equivalent to a signed char 128. Negative numbers are stored in 2s compliment form. Which means the binary for -1 is:
111111111 11111111
NOT: 10000000 0000000, which might seem to make more sense at first.
They use 2s compliment because it makes all of the standard binary operations work for negative numbers.
If you cast a signed int -1 to an unsigned int, you will get 65,535. When you cast from unsigned to signed it does not touch the binary of the variable, just how its interpreted. Just like how you can print the signed interpretation of an unsigned variable using %d in printf instead of %u.
The best way to understand whats happening when u cast unsigned to signed you really need to look up information on 2s compliment.
If you HAD to perform a shift, you would need to do it manually. Ex:
shiftedUnsignedVar = (unsigned int)(signedVar + 32768); or
shiftedSignedVar = (int)(unsignedVar - 32768);
As showed in fosters output that will match the example that you gave to start with.
Hope that helped,
Ken
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
pic: Dean and Woodie Signed Saftey Glass andrew348 Extra Discussion 8 27-03-2007 16:36
Labview dashboard and multiple variables Joe Ross LabView and Data Acquisition 2 15-03-2006 21:55
Math.h and Functions and Variables amateurrobotguy Programming 1 26-02-2005 03:19
problems assigning unsigned chars in FRC Code LoyolaCubs Programming 6 26-01-2004 23:21
My team is registered and signed up for Rutgers(rookie)! Erodge General Forum 5 11-10-2002 10:13
