Go to Post so instead of saying why, we said why not? - Alpha Beta [more]
Unread 05-01-2008, 23:45
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
"Signaling Device" reciever location?
I just finished reading the rules and then browsing through some of the IR Communication threads. One of the biggest problems that everyone has identified is that it might be difficult to communicate with the robot during the hybrid period with whatever IR signal.
After looking over the rules again, I was wondering if we would be allowed to put the IR receiver on the Operator Interface instead of the robot its self. If we could, it would make it easy to insure you can communicate with the robot for all 15 seconds of the hybrid period.
Thoughts? It seems like this shouldn't be allowed, but I couldn't find a rule to quote that says it isn't... Maybe you all can?
- Toby
Unread 05-01-2008, 23:50
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Re: "Signaling Device" reciever location?
I believe that it must be on the robot, but I'm not 100% sure.
I know at the kick-off they demonstrated the IR receiver worked better while channeling the IR beam through a tube. I also think there are no limits on how powerful the IR beam can be, so you could try messing around with some very powerful TV remotes.
Did they say if it was OK to have IR beam retransmitters? They work wonders on my television and could for the robot.
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 05-01-2008, 23:52
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Maybe you could, but it wouldn't be useful. You can't read inputs from the operator interface during autonomous (hybrid) mode.
Unread 06-01-2008, 00:22
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
Daniel, I believe you're right, because you'll have nowhere else to connect other than the Joy ports 1-4 which, in "hybrid" mode, would be disabled (to the best of my knowledge)
And Alex, I THINK that the IR extenders use RF waves, which then would make it illegal as it could potentially interfere with the radios used for controlling the robot, among other things. I could be wrong about this, I'm not sure, but to my knowledge they do run on Radio Frequency =S
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 06-01-2008, 00:24
FRC #0201 (FEDS)
Ok, thank you for answering my question. =)
'08, '09, '10
Unread 06-01-2008, 00:33
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
they would seem legal to me. (followed the parts flowchart)
a wired IR repeater schematic http://www.cedarnet.org/smartware/Ha...ater/index.htm
and some other cool IR stuff:
http://www.hobbyprojects.com/quick_c...chematics.html
hope those help you out
...forest
Unread 06-01-2008, 00:34
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
The OI data is still being updated during autonomous. We've used switches to set auto mode config in the past.
However, you would need to make an adapter board to connect the receiver.
Eric Haskins KC9JVH
Unread 06-01-2008, 00:40
fimmel's Avatar
AKA: Forest Immel
those switch inputs as far as i know are read before "hybrid" mode when the robot is disabled. since when the robot is disabled OI input is transmitted but outputs are not enables on the RC. in "hybrid" its the other way around. OI disabled, RC outputs enabled.
this is what i gathered from kevin's new code that he has been working on for the new compiler.
...forest
Unread 06-01-2008, 00:42
Interesting...I knew this was possible, but I didn't think that it would send varying data..I thought it just took the data that it initially started with and used that for the entire auto mode
and for the adapter board; is that legal (assuming that the OI data is sent during auto mode)?
[EDIT]oops I guess Forest confirmed that before I posted.
Thanks Forest[/EDIT]
Rohan K
Unread 06-01-2008, 01:50
AKA: Eric Haskins
I haven't read the rules throughly enougth to know, but I'd guess not.
Eric Haskins KC9JVH
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
Nationals Location "Pool" Ricky Q. Championship Event 103 18-11-2002 14:18
