Go to Post I think being successful in FIRST is creating an environment where people can grow, learn, change, and recreate... It's about making an environment where kids feel they can be successful... in whatever discipline they choose. - ColleenShaver [more]
Unread 06-01-2008, 00:18
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Cant get RC to work
I have never used this controller before, I just finished wiring up the motors RC OI etc... and when i powered it up all of the lights are flashing yellow. I have fully charged both batteries, what am i doing wrong?
Unread 06-01-2008, 00:28
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Cant get RC to work
Did you tether it to the Operator Interface?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 06-01-2008, 00:30
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
You must tether it to the OI to make sure the OI and RC are on the same channel and team number. Also you may want to make sure that any other robot may be off. By default all of the robots are on c_40(?), if you don't change the channel than there will be interference between the two robots even if the team numbers are different.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 06-01-2008, 01:16
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Still not working, i am using the tether, and on the UI i have c40 on the LCD and valid rx flashing on both the OI and RC columns, PWM 1 and 2 are solid, in the OI column TX is also flashing. Main battery voltage is 12.51 and the back up is 8.17.
Unread 06-01-2008, 01:23
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
You need to tether the OI and the RC together at least once after you have your team number with the dip switches (in binary) on the OI.
Once tethered it programs the team number in the board. Once that is done you are able to use the radios.
But, sometimes it's just easier to use the tether cable for early testing.
most of what you need to know is on http://www.ifirobotics.com/
Unread 06-01-2008, 01:26
AKA: Brennan Ashton
FRC #2605 (A2D_16)
I said nothing about radios, i am doing it in tethered mode. I have read through the documentation there with no effect.
Unread 06-01-2008, 01:53
Andy A. Andy A. is offline
Getting old
FRC #0095
Comphappy-
I am assuming you have already read the RC-reference guide on IFI. If not it is located here as a .pdf. I suggest if you haven't done so already you right click and save that file for future reference. One of the most important trouble shooting tools for the RC is on page twelve of the RC reference guide, table 8.3. This outlines what each of the LED color and blink codes on the robot controller means.
The blink codes for the Operator Interface can also be found through IFI, along with other helpful documents at http://www.ifirobotics.com/oi.shtml . In the OI reference guide, on page fourteen, tables 5.2.1 and 5.2.2 list the blink codes specific to the OI.
If you can't figure out what your blink codes mean, please post a detailed description of exactly which LED's are on and in what color and what the conditions are. I suspect that your problem is related to having your team number properly set, but there may well be a genuine hardware/firmware failure. If that is the case you'll want to contact IFI soon, but first lets make sure that it's not something simple that we can fix online. You didn't mention any red led's, so that means theres a 99.99% chance this isn't anything serious.
Good luck. Let us know what you find out.
-Andy A.
Unread 06-01-2008, 02:07
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Red Green color blind so here is a picture of it
Sorry that it is so blurry, i had to use a long exposure so that all the leds were lit.
All of them are blinking with the exception of Power On and the two PWMs
Unread 06-01-2008, 04:16
Getting old
FRC #0095
Comphappy-
It would seem that your controller and interface are healthy and operating fine. All lights are blinking green with the exception of the two PWM feedback lights, which is normal.
You've said that it isn't working. What, exactly, isn't working? The RC doesn't seem to be connected to anything, so aside from the feedback LED's there isn't any way to establish that it is operating correctly. I would suggest either using some servo's connected to PWM 1 and 2 and a joystick to confirm that pwm outputs are enabled, or connecting a computer with the dashboard program running to see the outputs.
Have you downloaded your own code to the controller? The program state LED is blinking green, which means there is a valid program, although it's easy enough to write a valid program that doesn't accomplish anything.
-Andy A.
Unread 06-01-2008, 10:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
From your picture, it looks as if you don't have your PWM cables connected. Also, if you have connected them, make sure they are plugged in properly so that the white wire is plugged into the SIG pin and the black wire is plugged into the black pin. Same with on the Victor; the white wire should be facing the outside of the Victor. I've also found that sometimes when you insert the plug into the hole, it does not make contact, and therefore, does not work. The easiest way to try to connect the PWM to the Victor is while the Victor and RC is on (but please be careful not to touch the power wires o the left).
Here is the PDF for the Victor: http://ifirobotics.com/docs/ifi-v884...al-9-25-06.pdf
And here is the Spike: http://www.ifirobotics.com/docs/spik...uide-sep05.pdf
Good Luck! If you have any questions, feel free to contact me.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 06-01-2008, 15:28
AKA: Brennan Ashton
FRC #2605 (A2D_16)
The dashboard shows things fine. So are those lights meant to be flashing all the time?
Unread 06-01-2008, 15:42
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
I have not turned on this year's controller yet, but in years past we have used the PWM LEDs as indicators for the driver. We set their state in the program. I didn't do that section, but in hobby projects I have misinterpreted what turns OEM board lights on/off. If they are pulled up internally, and you tell everything to initialize to 0, the lights will turn on. Check your code. Please correct my asumptions of the inner-workings if they are incorrect.
Unread 06-01-2008, 15:55
Getting old
FRC #0095
The old saying 'if it's blinkin' it's thinkin' comes to mind.
Yes, the lights are supposed to blink green or hold a solid green, depending on which one your talking about. The manuals linked earlier have the specific meanings of each LED, and what the norm is. From the picture you posted everything is working normally, so thats the state you should learn to recognize and love.
As for the program, I believe the default code enables PWM 1 and 2, with 1 mapped to the y axis on joystick port 1 and pwm 2 on joystick port 2. A programmer should be along shortly to correct me though.
The easy way to test that your PWM outputs are functioning correctly is to plug a servo into each enabled output and a joystick into the correct port. The servo should move with the joystick. Make sure that the backup battery is plugged in and charged though.
The dashboard program should also show you the state of each PWM output, along with a bevy of other information. It sounds like you've already played with this. It's a really useful tool thats underutilized, so keep using it.
-Andy A.
Unread 06-01-2008, 18:40
AKA: Brennan Ashton
FRC #2605 (A2D_16)
It appears that it was working all along, it is just the the blinking threw me off, usually when something is blinking it means that something is wrong and it is trying to get your attention. Anyway off to plow through the digi-key catalog for connectors and wire.
CANT GET THE CANERA CODE TO WORK!!!! plz HELP!! its da PAT!!! Programming 3 18-02-2007 23:07
first year team - cant get camera programmed sniggel Programming 12 20-01-2007 02:20
I cant get my program into a hex file Serge Programming 8 17-02-2006 03:28
cant get into autonomus blindguyinanorg Programming 7 20-02-2004 17:06
cant get to the Chat feature Elgin Clock CD Forum Support 4 28-01-2002 07:37
