Go to Post The robots that rise to the top will not be the ones that do everything poorly, but the ones that are breathtaking at one thing. Be that robot. - DampRobot [more]
Unread 06-01-2008, 00:27
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Cool Programming on an Asus Eee PC
Hey everyone, I was just recently introduced to the Asus Eee PC and I've been seriously considering buying one just to bring around with me when I need to do work and such. I especially think this would be perfect for programming a robot especially to carry around the competition (being only 2 pounds and all). It's also a really cheap laptop starting at $249.99 US. Now what I'm wondering is if it's possible to run MPLab and the C18 compiler on the system, seeing how it runs Linux, or if anyone has had experience with one of these systems. Thanks in advance!
Unread 06-01-2008, 00:39
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Programming on an Asus Eee PC
They run linux stock, but you CAN install XP on them, and use the standard mplab toolchain.
Unread 06-01-2008, 00:41
frewre06 frewre06 is offline
FRC #1777
frewre06 is an unknown quantity at this point
It is my understanding that the Eee runs windows xp (at least theoretically) . You would have to install the OS yourself as I don't believe it is sold pre-installed. It would be difficult to code efficiently on a screen and keyboard as small as the Eee's. That and with the memory and processor resources of the Eee, XP would be significantly slower than you might like.
That being said, it should be possible to write and upload code with the built in Linux/Unbutu (I think the Eee runs an Unbutu hybrid) tools. Though your programming skills could be put to the test as you would have little to no support that the IDEs that C18 and EasyC offer.
-S
Unread 06-01-2008, 00:45
And you can always use a portable hard drive on those things.
Unread 06-01-2008, 00:52
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
Desktop virtualization (something like VMware..I'm not sure whether or not it works with Linux...I would think it does) are perfect for this problem =)
You can continue running Linux, if thats what you prefer, and run Windows from inside Linux.
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 06-01-2008, 08:18
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
We're using 3 EEEs, communicating using WiFi, collaboratively coding in Gobby.
I couldn't get MPlab to install, so we ended up using Gobby, a customized makefile, mcc, and the Linux ifiloader.
Edit: We're running the mcc compiler under Wine.
Unread 06-01-2008, 09:44
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
You should be able to run Wine on it and then run the MPlabs compiler using Wine. There have been some posts on how to do that. This is a Linux IFI loader that you can use to download the code.
Let us all know how you make out with your development
Unread 09-01-2008, 00:12
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
We have switched to an EEEPC this year. I have installed XP Pro and MPLab and the whole procedure took a little over two hours. They are really neat machines and everyone on the team is amazed by it. I have assumed possession of the PC and currently am typing this post from it. My only gripe is that the screen size and resolution are bad and the keyboard is extremely small, but for what it is worth, it is a great little machine to carry around.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 09-02-2008, 07:59
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
I too am seriously considering buying an EEE PC. From what I heard is that it runs Eclipse, so I think you could program FRC with it.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 29-04-2008, 14:04
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
will these computers be able to code for the 2009 controller?
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 29-04-2008, 15:30
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I wouldn't try to run labview as thats hard on my MacBook Pro, but WinRiver should be ok.
Unread 29-04-2008, 19:01
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
The eee pc is not a weak little computer. The CPU is ok and the ram is also very good if you upgrade it. Also the flash hard drive is very fast at loading large files. If you install a SD flash card you can expanded the storage space as well. But with a 9" screen eee pc coming in the future I would wait and buy the new model coming out around the end of this year.
http://eeepc.asus.com/global/news04152008.htm
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 30-04-2008, 09:48
Brian J. R.'s Avatar
Brian J. R. Brian J. R. is offline
Pit Chief
AKA: Brian Richards
FRC #1983 (Skunkworks)
Brian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to behold
Send a message via AIM to Brian J. R. Send a message via Yahoo to Brian J. R.
I have been doing some moderately extensive research into the Eee pc as I am planning on replacing my Macbook with one. I bought a first generation Macbook that has been riddled with problems.
Eee pcs run a customized, tabbed version of Xandros, which through a few command line tricks you can get straight to the desktop. My father has been successful in running Xubuntu (Ubuntu using the Xfce desktop manager) and it is quite a little machine.
If you are looking to run XP either buy the xp dedicated machine where microsoft will sell you a copy for $40, or if you are daring try out ReactOS, a binary compatible with windows. It is still alpha however.
Mid 08, or actually within the month if I am not mistaken is when the refresh the Eee pc line with 8.9 inch screens, 20gb ssd for the linux and 12 gb ssd for the windows version.
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
programming JasonWestHigh Technical Discussion 1 13-01-2003 20:54
Programming Jack OCCRA 6 07-09-2002 15:19
Programming archiver 2001 10 23-06-2002 23:01
