Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 06-01-2008, 04:16
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Cant get RC to work
Comphappy-
It would seem that your controller and interface are healthy and operating fine. All lights are blinking green with the exception of the two PWM feedback lights, which is normal.
You've said that it isn't working. What, exactly, isn't working? The RC doesn't seem to be connected to anything, so aside from the feedback LED's there isn't any way to establish that it is operating correctly. I would suggest either using some servo's connected to PWM 1 and 2 and a joystick to confirm that pwm outputs are enabled, or connecting a computer with the dashboard program running to see the outputs.
Have you downloaded your own code to the controller? The program state LED is blinking green, which means there is a valid program, although it's easy enough to write a valid program that doesn't accomplish anything.
-Andy A.
CANT GET THE CANERA CODE TO WORK!!!! plz HELP!! its da PAT!!! Programming 3 18-02-2007 23:07
first year team - cant get camera programmed sniggel Programming 12 20-01-2007 02:20
I cant get my program into a hex file Serge Programming 8 17-02-2006 03:28
cant get into autonomus blindguyinanorg Programming 7 20-02-2004 17:06
cant get to the Chat feature Elgin Clock CD Forum Support 4 28-01-2002 07:37
