Go to Post Sooo....in the famous words of Douglas Adams, Don't Panic. - Conor Ryan [more]
Unread 06-01-2008, 00:18
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Exercise for the Robots' Electronic for not to ruin the Controlers:)
Hey Guys!
This is my Rookie year so I believe I need to practise first before touching the pieces that we took today
Do you know any experiment or kind of exercise that I can do before building the electric and electronic part for the robot or should I just play with the pieces and find my way??
Unread 06-01-2008, 00:30
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Exercise for the Robots' Electronic for not to ruin the Controlers:)
For the electronics components of the robot, there are certain rules you have to follow in the interest of safety.
Certain gauge wires to certain things, fuses, spikes, relays to certain things.. etc..
Use the following as a guide, and just build a test board with everything mounted to a piece of plywood or something for now, being sure not to cut any cables or trim any cables yet.
Your final electrical setup may vary from what is shown obviously with whatever components you decide to use or not use, but this will give you a good idea of how each component should be laid out and how they need to be hooked up.
http://www2.usfirst.org/2008comp/Man...on_Diagram.pdf
Good luck!
Unread 06-01-2008, 04:34
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
In one phrase RTFM, really read the manual and check out the wiring diagram before you do any real stuff, get confortable with the system then you can fiddle around. I'd say look into if you've never done it before practicing crimping wires of the diffrent gauges to make sure you get good connections. Best of luck to you
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Unread 06-01-2008, 04:40
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
If possible try and get access to an older robot from previous years. That will help you get ideas.
Other than that the best advice i can give you is... make sure you have an accessible design. keep the RC, battery and PWM's accessible. There is nothing that slows down a team more than having to dig through wires and around gearboxes to try and fix a problem. I learned that the hard way.
Unread 06-01-2008, 09:45
in between teams
AKA: Luke Van Oort
Yep, that is definitely key. Our electrical setup last year was crammed into a really small space (our turret took up almost half of the robot) and it really hurt us. Our first qualifier at Palmetto we couldn't even take to the field because the common wire from the battery fell out of the distro block in queuing, and it was too difficult to reach to be fixable in the short amount of time we had. The following match we couldn't score because, in the process of fixing the first problem, we had accidentally unplugged the solenoid that controlled our gripper actuator. Don't be like us and learn the hard way; make accessible electronics.
Team 1219: 2009 - Mentor
Last edited by lukevanoort : 06-01-2008 at 11:15. Reason: should have proofread it again...
Unread 06-01-2008, 10:45
Practice crimping your wires. Crimp a wire, tug on its connector a few times. Repeat until you can reliably get it to stick.
Bad crimps have a high "badness caused" to "difficulty to fix" ratio, so it is a good place to invest a little time.
For those of us who may not quite be in the holiday spirit... Jay Trzaskos Chit-Chat 19 24-12-2006 21:53
TRIPLE REPLAY ... the consequence for not doing Dean's homework! Natchez FRC Game Design 36 11-05-2005 18:52
A Real Transformer? (the robots, not the electrical component) Nick Seidl Chit-Chat 2 02-04-2004 12:23
She'll cheer for the Nimrods, but not for FIRST? Nick Seidl Chit-Chat 3 26-03-2004 15:03
Segway not in time for the Holidays MattK Dean Kamen's Inventions 8 10-11-2002 00:31
