Re: How do you get your other ball
Well it says that a robot shall not be taller than 6', It never says that the robot can not be above the 6ft plane. Lets say the ground were higher, or... it was on a ramp-bot. Then the bot on top could be under 72" tall (NOT under 72" from the ground) and still have some room to play with. Now that's an interesting strategy, I think. That's also probably a strategy that nobody'll take (enough with ramps already) and would still get you penalized (for being a smarta -- yeah).
Especially since one of the dictionary definitions of height is "The distance from the bottom to the top of an object." Also, knocking off opponent's ball = they lose 12 points. Doing it in their home stretch, you lose 10. If the scores are even, that's a decent strategy. It'd win a match, that's for sure. |
that would enable your team to also score on both overpasses during the endgame (unless you just score on your own side of the overpass...) |
New Trackballs 'casue you popped the one in the KOP: $12. Thinking out strategies like a FIRSTer: Priceless. There's some things money CAN buy. For everything else, there's FIRST. |
How about the flag? The flag must be placed so it is 75 inches from the ground. Last time I checked, that is taller than 6'. So that means your robot could never do a lap ...
I expect some clarifications on this rule. I will ask a question as soon as the Q & A is up. |
Correct, as per <R13>, emphasis mine:
You ONLY have to be under 6' in the opposing alliance HOMEZONES. Example below.
![]() If a team is on the BLUE ALLIANCE, they can be above 6' everywhere except in the RED HOMEZONE. If a team is on the RED ALLIANCE, they can be above 6' everywhere except in the BLUE HOMEZONE. It is 100% legal to knock the ball BACKWARDS off of the OVERPASS(clockwise). So pass through the opposing HOMEZONE, pause, knock ball BACKWARDS, and go. Last edited by Chuck Glick : 06-01-2008 at 13:21. Reason: clarification, image update. |
#9
#10
If the trackball is still on the OVERPASS, on the opposing side, it has not crossed ANY lines. Knocking it backward would be completely legal at the beginning of a match, or initially just to get the ball down for your own use.
People are concerned that the track ball that is on the side opposite of theirs is impossible to retrieve without breaking rules. |
#11
EDIT: Original Drawing Updated. Last edited by Chuck Glick : 06-01-2008 at 12:56. |
#13
I haven't done the math, but it seems to me that if the ball is sitting on the rail, and the rail is directly above the finish line then the ball should extend beyond the finish line ... thus you should be able to knock the ball off of the rails by striking the part that is beyond the opponents finish line without your robot being in their "home strech" or breaking the plane of the finish line.
#14
I am confused. Page 5 of 7 of THE ARENA. As the ROBOTS move in a counter-clockwise direction around TRACK, the quadrant of the TRACK immediately preceeding the the FINISH LINE for each alliance is known as the "HOME STRETCH" Wouldn't that mean that the finish line itself is not part of the home stretch? The home stretch is bounded by the finish line. Does that mean the finish line is part of the home stretch? Or does it mean that the leading edge of the finish line is the boundary? I tend to think that since the wording says the home strech is the quadrant of the track immediately preceeding the finish line, that the Home Stretch does not include the area above the finish line, but rather the area before the finish line. Last edited by ALIBI : 06-01-2008 at 17:36. |
#15
Just like the ball hangs down under the overpass, the ball also crosses over the plane of the homestretch. This makes it possible but difficult to knock that trackball off by turning around once you are out of the other teams homestretch.
| How early in the season did you get to test your programming? | EHaskins | Programming | 18 | 20-02-2007 00:22 |
| How did you GET your job(s)? | JVN | Career | 45 | 18-02-2006 15:07 |
| How Did You Get Your Sponsor? | Summmergrl2298 | Chit-Chat | 7 | 30-01-2002 23:40 |
| How to get your picture under your username: | Brandon Martus | CD Forum Support | 0 | 07-01-2002 09:23 |
