Go to Post Students... be sure to drill air holes in the crate though. Maybe toss in some cheetos for the programmers. - Andrew Schreiber [more]
Unread 06-01-2008, 05:56
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: How do you get your other ball
Well it says that a robot shall not be taller than 6', It never says that the robot can not be above the 6ft plane. Lets say the ground were higher, or... it was on a ramp-bot. Then the bot on top could be under 72" tall (NOT under 72" from the ground) and still have some room to play with. Now that's an interesting strategy, I think. That's also probably a strategy that nobody'll take (enough with ramps already) and would still get you penalized (for being a smarta -- yeah).
Especially since one of the dictionary definitions of height is "The distance from the bottom to the top of an object."
Also, knocking off opponent's ball = they lose 12 points. Doing it in their home stretch, you lose 10. If the scores are even, that's a decent strategy. It'd win a match, that's for sure.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
How early in the season did you get to test your programming? EHaskins Programming 18 20-02-2007 00:22
How did you GET your job(s)? JVN Career 45 18-02-2006 15:07
How Did You Get Your Sponsor? Summmergrl2298 Chit-Chat 7 30-01-2002 23:40
How to get your picture under your username: Brandon Martus CD Forum Support 0 07-01-2002 09:23
