Re: Throwning the ball over the over Pass
alright our team has been discussing this option a lot...but I realized that the catapult idea wouldnt work if they wanted to say...hurdle...the ball
first off, in the definition of hurdling, it states "be moving toward the OVERPASS and/or elevating the TRACKBALL so that the top of the TRACKBALL is higher than the LANE DIVIDER." that means ure catapult will have to start at 6 feet (ht. of lane divider) in order for your robot to succesfully hurdle correct me if Im wrong... |
Joey |
well the trackball itself is 40 inchs high on the ground, giving the facthat it is the "TOP" of the trackball must be over 6ft. the ball is already 3' 8" without any support so really the catapult only needs to hold the ball up another 2' 4" which realy isn't a big deal! |
The rules could care less about how a Trackball gets above an overpass. You should be able to use a catapult, even if you are setting still and the top of the Trackball is not six feet off the ground. You will not be getting the protection of G42 if you are not moving towards the overpass tough. |
yea your right i dont see anywhere where it clearly states that you have to throw the ball in that motion which leaves alot of options open
So that means that if............
---------------------------- / Robot was | \ / O <- here | \ |_____________ | ___________ | | Alliance | Ball could | \ Home | be thrown / \ Stretch | here -> O / ---------------------------- ...........and still count as a hurdle. As long as it passed over the alliance's overpass, Our team believes it would, and the only down fall was that the robot wouldn't be considered "hurdling" and under the protection. *If I'm wrong please let me know. I don't see anything wrong with it though. |
#7
My last post had a text picture that did show up so below should be a corrected pic.
Apparently spaces don't show up????? ????????..................----------------------------.................................................. ................/ Robot was.....|...................\..................... ........................... .............../ O <- here.......|....................\................. .............................. ..............|_____________ | ____________|..................................... .......... ..............|......Alliance..... |....Ball could....|........................................ ...... ...............\......Home........|...be thrown..../............................................... ................\....Stretch......|.....here -> O /................................................ ..................----------------------------.................................................. |
#8
to ccsingle07
yes, I think. It is traveling counter-clockwise, so I see no problem with this. |
#9
anybody know of a fairly reliable formula for figuring out air resistance on the ball?
I've looked up the formulas online, but all I'm able to find is "high velocity" formulas and I'm not sure what exactly a "high velocity" would be. |
#10
Unless I have messed up my kinematics, an initial velocity of 6.25m/s should launch an object 2m into the air, which should be plenty for hurdling. Given that this is about 23km/hr, I suspect you could adequately account for air resistance by just aiming to put the ball 30cm or so over the crossbar.
Now how you accellerate the ball to 6.25m/s... that's another issue. Jason |
#11
Cd = 0.1 for Reynolds number ~666k (10m/s)
http://simscience.org/fluid/red/reynolds.html Turn CD into a Force at velocity x by using info from here: http://en.wikipedia.org/wiki/Drag_coefficient Extra credit Integrate air drag loss to peak of trajectory and you get an idea of how many joules extra kick to give it vs doing this in a vacuum. Regards Frank |
#12
"Storage achieved by deformation of ROBOT parts. Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe." It is probably safe to assume that a robot which stores enough energy with steel springs, latex tubing, etc. to throw a track ball over the overpass might have trouble passing inspection because of the safety issue of, for example, the possibility of releasing this energy suddenly into someone's head. |
#13
Today team paragon tried a mock game with students and a ball. We tried to toss the ball over the overpass but it didn't work out to good we only got it once. Also when we threw it over after the field was built someone got knock down on to the floor.
#14
No you cant throw the ball over backwards, look at the definition of crossing
Joey |
| What is your team going to do with the rack after the season is over? | Ben_pharteen | General Forum | 51 | 14-04-2007 15:27 |
| What will the winners have over the rest of us | Ben Lauer | General Forum | 21 | 26-02-2005 00:17 |
| Rules for hanging, using a loop over the end of the bar | caffel | Rules/Strategy | 10 | 04-06-2004 15:04 |
| Knocking over Ball via Tee | tminard | Rules/Strategy | 2 | 07-02-2004 11:35 |
| Height of the bar over bonus ball structure | punarhero | General Forum | 3 | 17-01-2004 14:39 |
