Go to Post Besides, you know hard it is to solder with gloves on? - Al Skierkiewicz [more]
Unread 05-01-2008, 22:59
ZP8892's Avatar
ZP8892 ZP8892 is offline
FRC #0369
ZP8892 is an unknown quantity at this point
Send a message via AIM to ZP8892
Trackball scoring
I need help in figuring out if you gain points for keeping (possessing) the trackball and crossing the finish line. Please help me out!
Unread 05-01-2008, 23:12
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Trackball scoring
Your alliance will score 2 points for the robot crossing the finish line; the trackball will not score UNLESS a) you drop it as you cross or b) the trackball is in contact with another alliance's robot (see <G10>). If either a or b occurs, your alliance will gain another 2 points.
Hi!
Unread 06-01-2008, 00:08
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
The way I read <G10>, "not in contact," could mean one of a few things. What if you're arms just sort of...incase the sides of the ball. The bottom, grazing the floor. Then, technically you're "in possession" according to this definition:
POSSESSION: Controlling the position and movement of a TRACKBALL while the TRACKBALL is supported or captured by an ALLIANCE shall be considered POSSESSION of the TRACKBALL. ... A TRACKBALL shall be considered “captured” by a ROBOT if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the TRACKBALL remains in approximately the same
position relative to the ROBOT. Both the “supported” and “captured” conditions include the case where the TRACKBALL is also in contact with the floor.
BUT, you're not actually "IN CONTACT." Would you get 2 points, or not?
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 06-01-2008, 00:11
Taylor's Avatar
AKA: @taylorstem
If you back up, will the trackball follow? If so, you're in possession. If not, happy scoring.
I would guess the referee would err on the side of contact.
Hi!
Unread 06-01-2008, 00:14
BandChick's Avatar
AKA: Sara Reffler
But <G10> says, and I quote:
<G10> Each TRACKBALL that has CROSSED its own FINISH LINE while not in contact with a ROBOT of the same ALLIANCE will earn 2 points. A TRACKBALL that has CROSSED its own FINISH LINE which contacts ROBOTS of both ALLIANCES while CROSSING will earn 2 points.
It doesn't say anything about possession of it.
Unread 06-01-2008, 00:17
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Yeah, I'm pretty sure that means that pushing, herding etc. is out. When the ball crosses NO PART of your robot may touch it. Hence no contact.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 06-01-2008, 08:52
GaryVoshol's Avatar
Cogito ergo arbitro
It's going to have to be apparent that there is no contact. If you're relying on the ref seeing a millimeter of air between your robot and the ball, maybe you might want to think again.
(since 2004)
Enevitable- Trackball popped pheadxdll Kit & Additional Hardware 30 03-02-2008 08:08
Scoring Ian Mathew General Forum 25 10-01-2007 14:54
Scoring G1279 Rules/Strategy 7 10-01-2007 14:48
Scoring Vincent Chan Rules/Strategy 4 08-03-2003 23:57
y = ax(2) + bx + c ---???Scoring???---- tenfour General Forum 3 21-12-2002 10:26
