Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 06-01-2008, 11:44
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Wondering if we can use steal for our frame
Hey guys i was wondering if anyone knows if we are able to use steel on for our frame instead of the metal given in the kit? I couldn't find this anywhere in the manual so thats why i ask.
Thanks, Dani.
Unread 06-01-2008, 11:47
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Wondering if we can use steal for our frame
Steel is a commonly used product by many teams. You do not have to use the kitbot provided in the kit of parts. As long as it fulfills all of the rules for it to be a COTS item, then it is legal.
Nate Laverdure's Avatar
FRC #2363
Yep. Just don't steal your steel.
Unread 06-01-2008, 11:49
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
you can use steel, but it will be heavy. the kit frame is a good frame to use, we've been using it for the past 2 years and will be using it again this year.
2005 - GTR WFFA
2006 - Waterloo Regional Champions with 1114 and 1503
2010 - Waterloo Rookie inspiration and Highest Rookie Seed, #2 Alliance Captain, Semi-finalists.
2011 - Waterloo Finalist thanks 1310 and 610
2014 - imagery and rookie allstar award gtr west
2014 - rookie inspiration and winners with 188 and 610 north bay
Billfred's Avatar
Billfred Billfred is offline
Even better, check the Parts Use Flowchart at the end of the Robot section of the manual. That holds all the answers.
Unread 06-01-2008, 11:50
AKA: Dani
ok thanks a lot guys.
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
And also make sure that you still can come in under the weight limit. That never a good thing trying to lose 1-2 LBS on Thursday at a regional.
Unread 06-01-2008, 12:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You could make a frame just as stiff and strong as any aluminum frame if you could afford some 4130 tube, you know. It's 3 times the density, modulus, and yield as 6061 and anyone with a MIG can weld it. Now, it's also at least 3 times the cost.....
Unread 06-01-2008, 12:21
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Or 20 or 30 lbs....
Unread 06-01-2008, 13:40
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Thanks, Dani.
Dani,
If steel is your only choice, then it is perfectly legal.
As others have stated, there are lighter options, and in a few weeks you may be looking hard for a few pouinds, so it might be better to go with something lighter now.
The kit bot frame is good and strong and lightweight. If you have the capability to weld, aluminum tube (usually square or rectangle) is a great choice.
This might be a good material to practice using the material flow chart on - you should come out with the answer that it is OK to use.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-01-2008, 13:46
Gabe15's Avatar
Gabe15 Gabe15 is offline
FRC #1584
Gabe15 is an unknown quantity at this point
I agree, if you can get your hands on some chromoly (4130) it is really good stuff. We got a bunch for free last year and it did a great job of keeping our frame from ripping apart when lifting 300lbs of robot!
Unread 06-01-2008, 13:50
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
I feel like there is a joke in the title...
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
can we use our arms as measuring devices railerobotics FIRST Tech Challenge 1 04-02-2006 13:24
Can We Use A N64 Controller To Control Our Robot??? pobots Rules/Strategy 1 11-02-2003 23:14
Can we use part of a container on our robot? Rick General Forum 1 10-02-2003 20:10
Can we ground our wires to the frame? mnkysp6353 Electrical 1 15-02-2002 20:47
What box can we use for our custom OI interface DanBlock Technical Discussion 1 15-02-2002 17:09
