Go to Post I'm always shocked when I see wiring having a bad hair day. - JaneYoung [more]
Unread 06-01-2008, 12:32
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
<R11>Conifguration Question
Hello,
<R11> states Maximum Width, Depth, and Height dimesnions (sorry, I was not able to copy and paste the box). Are you allowed to have your width as 38 and length as 28 as in past years? Will you have to start sideways? Thank you!
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 06-01-2008, 12:39
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
Re: <R11>Conifguration Question
It does not matter which way is front and you can start in any position. Correct me if I'm wrong.
2010-present - NC State University Underwater Robotics Team
ncsurobotics.com
2007-2009 - FRC 2108
2006 - FRC 926
Unread 06-01-2008, 12:41
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
You can orient your robot in whichever direction you want within a 28x38" rectangle. Some robots are omnidirectional, and thus do not have a front, back, or sides.
Sykan's Avatar
Sykan Sykan is offline
Lead Programmer
AKA: David
FRC #0540 (Team 540)
Sykan is on a distinguished road
I Think you can Start which ever way you want. As long as all three robots fit in the starting position box. I may be wrong
Unread 06-01-2008, 12:42
in between teams
AKA: Luke Van Oort
You're right. You can even use the 60" dimension as your width if you design your robot to flop over at the beginning of the match.
Team 1219: 2009 - Mentor
Unread 06-01-2008, 12:46
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Rob2713g View Post
Hello,
Dimensions are 38"x28"x60" starting size.
The only restrictions are:
<R11> Prior to the beginning of the MATCH, the ROBOT shall be placed in a STARTING CONFIGURATION that fits within the dimensions listed below:
Maximum
Width
28 inches
(71.12cm)
Maximum
Depth
38 inches
(96.52cm)
Maximum
Height
60 inches
(152.40cm)
Maximum
Weight
120 pounds
(54.43Kg)
Any restraints (elastic bands, springs, etc.) that are used to restrain the ROBOT in its STARTING CONFIGURATION must remain attached to the ROBOT for the duration of the MATCH.
<G17> ROBOT Starting Size - At the beginning of a MATCH, each ROBOT must not exceed the maximum weight or volume specified in Rule <R11>. The Head Referee may call for an inspector's recertification of the ROBOT size and weight prior to the start of any MATCH. ROBOTS in violation will be prohibited from participating in the MATCH.
<G18> ROBOT Orientation - ROBOTS must start the MATCH with their long (maximum) dimension in a vertical orientation. After the start of the MATCH, ROBOTS may change their orientation such that the long dimension is either vertical or horizontal. Refer to Rule <R08> and Rule <R17> to determine how this affects the use of STANDARD BUMPERS and FLAGS.
The long dimension is the 60"
___________________
- Tennyson, Ulysses
Unread 06-01-2008, 12:58
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
True, but pay attention to:
<R17> ...The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in any PLAYING CONFIGURATION and the FLAG is in the flag holder, the FLAG is approximately vertical and the top of the FLAG is 75 inches above the floor.
The definition of PLAYING CONFIGURATION is
... after the MATCH has started, and the ROBOT has deployed mechanisms, moved away from the starting location ...
so you'd need to mount the flag holder perpendicular to the running (flopped) base. I bet that would confuse a few queuers!
Pete Kieselbach
I'm guessing that we are going to see robots that come in well under this size envelope this year. I'm rather excited for the prospect to see some really lean, agile bots. If you are half as wide, you can get through spots that would otherwise be a brick wall.
Unread 06-01-2008, 13:00
Mad Scientist
AKA: Me
FRC #2040 (DERT)
But you could roll that much easier
___________________
- Tennyson, Ulysses
Robot Size- R11 vs. Inspection Checklist Toby314 Rules/Strategy 4 07-01-2008 10:09
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
