Go to Post Common sense goes a long way. - Akash Rastogi [more]
Unread 06-01-2008, 12:58
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: <R11>Conifguration Question
Originally Posted by lukevanoort View Post
You're right. You can even use the 60" dimension as your width if you design your robot to flop over at the beginning of the match.
True, but pay attention to:
<R17> ...The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in any PLAYING CONFIGURATION and the FLAG is in the flag holder, the FLAG is approximately vertical and the top of the FLAG is 75 inches above the floor.
The definition of PLAYING CONFIGURATION is
... after the MATCH has started, and the ROBOT has deployed mechanisms, moved away from the starting location ...
so you'd need to mount the flag holder perpendicular to the running (flopped) base. I bet that would confuse a few queuers!
Pete Kieselbach
Robot Size- R11 vs. Inspection Checklist Toby314 Rules/Strategy 4 07-01-2008 10:09
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
