Go to Post A person is not defined by what mistakes they make, but more so by what they do after they realize their mistake. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-01-2008, 13:07
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Quadrature shaft encoder source
I have seen in a couple threads that teams have used a specific Quadrature encoder for various projects. The one I can't seem to find is usually red, about the same size as a standard rotary pot but has four pins coming out of the back.
What I would like to know is where I can purchase these. I have searched several sites including: McMaster, SparkFun, All Electronics and Jameco with no results. I don't mind using a different encoder, I just like the size and configuration of that one. If you would recommend a different encoder for FRC, please advise on that as well.
Unread 06-01-2008, 13:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Quadrature shaft encoder source
Check US Digital. Might not be that exact one, but they have quite the selection.
Unread 06-01-2008, 13:25
billbo911's Avatar
Yep, I looked there as well and they do have some very useful options. We are considering them as well. What can you say when you can get an encoder for less than $20 that has 360 PPR? Sweet!!!
Thanks Kevin!
Unread 06-01-2008, 14:22
Kevin Watson's Avatar
La Caņada High School
FRC #2429
www.grayhill.com available at digikey. Geared correctly, the 63R128 and 63R256 are pretty good encoders.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-01-2008, 14:23
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Red that looks like a potentiometer sounds like this part number:
EM14C0D-E28-L064S
From digikey
It's only 64 counts per rev but a complete package.
( If you are adventurous and can build your own interrupter wheel... or HAVE an interrupter wheel look into the honeywell HOA0901 which is an all inclusive dual channel digital detector with both phases in a single package. It doesn't need to be aligned and doesn't use a 4 equal phase scheme so a small number of interrupts doesn't work well, but I tested it with 8 interrupts and it seemed to work. Not accurate enough for an inkjet printer but probably accurate enough for any FIRST application you might have.)
But... I digress...
Steve Alaniz
Unread 06-01-2008, 17:24
billbo911's Avatar
-Kevin
EM14C0D-E28-L064S
From digikey
Steve Alaniz
Kevin and Steve,
Thank you both. These are great solutions. We will consider them both as well as the ones Kevin Sevcik suggested ,when it comes time to determine if we can use the KOP GTS or if we NEED directional information as well, and choose a Quadrature solution.
Thanks again.
Unread 06-01-2008, 19:21
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Bilbo,
If you have any "one turn" needs, the USDigital Absolute analog 'pots' are amazing.(no stop and 0-1023 range at less than the cost of a precision pot)
They also stock some really useful Quadrature to Analog interfaces if you'd rather not deal with interupts.(etachs for velocity + direction, edacs for position even in multi turn scenarios)
Unread 06-01-2008, 19:52
billbo911's Avatar
Originally Posted by 1680Bruce View Post
Billbo,
They also stock some really useful Quadrature to Analog interfaces if you'd rather not deal with interrupts.(etachs for velocity + direction, edacs for position even in multi turn scenarios)
Cool! Thanks for the suggestion.
The great thing is, there is always more than one way to "skin a cat". We will just have to figure out which way is the best match for our design needs and budget.
Problem using VEX shaft encoder jskene Programming 15 28-10-2007 22:33
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
Turning a gear-tooth sensor into a quadrature output encoder Jared Russell Programming 4 18-01-2006 22:19
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
