Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Unread 05-01-2008, 20:21
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Backup Battery
Just because you can't use the CMUcam doesn't mean you can't use your own modified visual system. Either way, telling the bot which to knock off would be based on the human player's signals to the bot. "Hybrid" mode they now call it.
Unread 05-01-2008, 20:25
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Lightbulb Re: Backup Battery
Although if you have good programmers you can program the robot to automatically navigate to the ball instead of useing more buttons.
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 05-01-2008, 20:33
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
Re: Backup Battery
the dots just seperate the balls from the views of the refs, as referred to above.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 05-01-2008, 20:40
seg9585's Avatar
AKA: Eric
Re: Backup Battery
I was responding to your post questioning the usefulness of the circular or noncircular marks on the balls for autonomous purposes if both teams have each logo and the balls are placed randomly. Autonomous programmers would use the ball's color before considering the markings on the ball, although the human players could indicate the correct logo to look for if they wanted to.
Unread 05-01-2008, 20:43
AKA: Micro3000x
I would understand if both balls one color were dotted and of the other not, but it's one dotted and one not dotted for each color. Only would benefit if 2 red or blue balls went over at the same time, but even than not that important.
Unread 05-01-2008, 20:53
seg9585's Avatar
AKA: Eric
Re: Backup Battery
The symbols are probably so the refs know which balls have been pushed all the way around the track to score extra points
Unread 05-01-2008, 21:58
AKA: Micro3000x
Thanks, that never came to mind, just thinking about putting the ball up.
Unread 06-01-2008, 01:09
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Backup Battery
Originally Posted by RyanN View Post
I do NOT think you can use the camera this year as of rule R36.
<R36> COTS ITEMS from ROBOTS entered in previous FIRST competitions or COTS
MECHANISMS that are no longer commercially available may be used under the following
conditions:
• The item must be unmodified, and still in its original condition as delivered from the
VENDOR
• The item must not be a part custom made for the FIRST competition and provided in the
Kit Of Parts for a previous FIRST Robotics Competition (e.g. 2006 FRC transmissions,
custom-made motor couplers, custom sensor strips, 2006 IFI CMUcam II modules, etc.
are not permitted)
• The item must satisfy ALL of the rules associated with materials/parts use for the 2008
FIRST Robotics Competition)
Please correct me if I'm wrong, because I would love to use the camera this year for autonomous.
The CMUCam actually doesn't fall under this category, as it's not manufactured specifically for FIRST. It actually comes from the fine folks at Carnegie Mellon University (hence the name), you can see the website here.
The one downside is I think the servo mount for the camera is custom made, so you'd have to machine one yourself, or else find a servo gimble from another vender.
--Ryan
Unread 06-01-2008, 01:38
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: Backup Battery
the reason it says 2006 CMU2 cameras are not allowed is because they updated the camera fro 2006 to 2007 and the 2006 cameras are no longer in production. making them not COTS items.
...forest
Unread 06-01-2008, 04:22
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: Backup Battery
Originally Posted by BQuennell View Post
Also on the backup battery, I'm curious to if we can use a backup battery charging circuit from last year. It doesnt list any design in the manual and rule R49 lists
When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. or any similar charging circuit (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
With that does that mean teams can design their own circuit as well?
It is my understanding that a backup battery charging circuit is recommended. I also take it that you can design your own. The one from IFI is not supported, and is there as a guideline/sample. You basically are taking your own risks.
I was seriously thinking about building a charging circuit for it last year. But, it turned out for some reason we didn't need it. I guess out of luck I actually got them to charge well.
Unread 06-01-2008, 04:36
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Backup Battery
The backup battery serves to power the RC during 'brown outs' and as positive voltage on the middle pin of PWM outputs. Effectively this means that it powers servos and saves you from your robot shutting down and resetting under heavy loads and low batteries. In the past we would have loved to have this kind of backup..
The charging circuit published by IFI in the past isn't all that great. Unless your robot is using a great number of servos or sensors powered by a PWM output it probably isn't nessecary to include the backup charging circuit. Simply charging the battery off the robot every few matches is perfectly adequate.
It is however required to include the backup battery on the robot and connected to the RC. The included battery pack is fine, but it is acceptable to replace it with any 7.2v battery pack (these are common in R/C cars, and you can get very high capacity packs if you so desire).
-Andy A.
Unread 06-01-2008, 10:07
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Backup Battery
Team 1629 designed and built an on-board charger circuit for 2007. It was based on the "Improved" charger design that was released late in the build season (the one that showed the extra battery terminal that was required).
The schematic and PCB were designed with the free software from ExpressPCB.com.
The board is larger than it needs to be (2.5x3.8) but this is their economic "Mini-pcb" size. By keeping to this size you can get 3 pcb's made in 3 days for less than $60. Build one for real, one for a spare and give one away
I've attached a zip to this message. It includes a pdf of the schematic and PCB as well as the actual ExpressPCB files. So you can go to ExpressPCB.com, download the software, open the PCB design file and then "Order Online".
It was great not having to remember to remove the battery to keep it charged.
This circuit also has pads for including a blocking diode so that the backup battery cannot back-power the RC. This was not included in the "official" schematic" so if you want to play by the letter of the law, just insert a wire in place of D3.
Also note that R1 and R4 dissipate power (get hot), so make sure you use at least 2W resistors.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 06-01-2008, 14:12
AKA: Micro3000x
--Ryan
That is true, but it was a kit of parts-supplied compnent both years.
Kit Of Parts
are not permitted)
Unread 06-01-2008, 14:14
Nate Laverdure's Avatar
FRC #2363
Re: Backup Battery
are not permitted)
To be prohibited, the item must be custom-made for FIRST AND be provided in the kit. The CMU cameras only meet one of the two parameters.
Unread 06-01-2008, 14:17
AKA: Micro3000x
Re: Backup Battery
That definition could be interpreted very loosely, but I do understand what you mean (although it doesn't apply to the 2006 module)
Backup battery failure comwiz7 Electrical 1 20-02-2007 07:40
backup battery carbuff Electrical 1 19-02-2007 08:28
backup battery nirty Electrical 1 08-02-2006 14:40
Backup/EDUBot Battery Phil_Lutz Electrical 7 27-01-2004 22:56
Backup battery and IR Matthew_H Electrical 6 21-01-2004 22:13
