Go to Post If you have time at a competition, stop and thank some of the people wearing the crew shirts. They are working very hard to make sure the competition goes as smoothly as possible. - Greg Young [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-01-2008, 14:23
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Quadrature shaft encoder source
Red that looks like a potentiometer sounds like this part number:
EM14C0D-E28-L064S
From digikey
It's only 64 counts per rev but a complete package.
( If you are adventurous and can build your own interrupter wheel... or HAVE an interrupter wheel look into the honeywell HOA0901 which is an all inclusive dual channel digital detector with both phases in a single package. It doesn't need to be aligned and doesn't use a 4 equal phase scheme so a small number of interrupts doesn't work well, but I tested it with 8 interrupts and it seemed to work. Not accurate enough for an inkjet printer but probably accurate enough for any FIRST application you might have.)
But... I digress...
Steve Alaniz
Problem using VEX shaft encoder jskene Programming 15 28-10-2007 22:33
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
Turning a gear-tooth sensor into a quadrature output encoder Jared Russell Programming 4 18-01-2006 22:19
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
