Go to Post everything's bigger in [strike]Texas[/strike] Canada. - lukevanoort [more]
Unread 06-01-2008, 14:38
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: Reading gyro before Autonomous mode
Originally Posted by artdutra04 View Post
Last year for our drive-by autonomous mode, we used a gyro on our arm to get the angle that we had to turn to. As soon as the robot was turned on, we set the code to initialize the gyro (which takes a few seconds) on our arm before autonomous started. As soon as the gyro is initialized, it would sit right around 0, but over long periods of time the default value can drift as much as 15 degrees over a two or three minute period.
So you did the initialize routine before start of automode? If so that is good.
Doug Leppard
Gyro Autonomous Problems cprogrammer Programming 5 23-03-2007 14:28
How to end an auto mode after gyro gets out of deadband kiettyyyy Programming 17 20-04-2006 07:59
Reading switches during Autonomous TimeOut Programming 3 19-02-2006 16:23
Gyro not working in Autonomous? kaszeta Programming 7 11-02-2006 01:28
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
