Go to Post Geez, now I'm like some all-knowing all-seeing FIRST sage who lives in the moutains waiting for students to venture upwards to my home to ask me if there will ever be a water game....:rolleyes: - Koko Ed [more]
Unread 06-01-2008, 15:04
MNov's Avatar
MNov MNov is offline
Giant deceptive face
AKA: Matan Nov
FRC #2230 (Zacharia's Angels)
MNov is an unknown quantity at this point
Quick clarification regarding crossing the finish line
<G10> Each TRACKBALL that has CROSSED its own FINISH LINE while not in contact with a ROBOT of the same ALLIANCE will earn 2 points. A TRACKBALL that has CROSSED its own FINISH LINE which contacts ROBOTS of both ALLIANCES while CROSSING will earn
2 points.
Now, I understand what's written here, but since this is probably one of the most crucial, potentially game breaking rules, I just want to know if I understand completely.
A robot holding the trackball passes through the finish line, the team gets 0 points, correct?
A robot herding the ball bumps into the ball while it's still on the finish line, the team gets no points, correct?
A robot with a very long arm lifts the ball above the overpass, takes it to the other side, and then drops it, does the team get 0, 2, 6 or 8 points?
Thanks.
Unread 06-01-2008, 15:07
Dizzy_Lizzy's Avatar
Dizzy_Lizzy Dizzy_Lizzy is offline
AKA: Lizzy W
FRC #0709 (Femme Tech Fatale)
Team Role: Electrical
Dizzy_Lizzy has a spectacular aura aboutDizzy_Lizzy has a spectacular aura about
Send a message via AIM to Dizzy_Lizzy
Re: Quick clarification regarding crossing the finish line
well a robot holding a trackball would get two points I believe. none for the track ball but two for the robot crossing. In the arm situation the robot will get 8 points for the hurdle only if it releases the ball before it crosses the line.
Team 709 '07: The Pink Flamingo
attended: Philly (quarter finalists w/ 365 and 316), Chesapeake
Beware Girly Death!
Unread 06-01-2008, 15:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
In the first two scenarios you describe, you get no points for the ball CROSSING the line, but you will get the two points for the robot CROSSING the line. In the third scenario, you get eight points from the ball: six for HURDLING, two for CROSSING. If the robot CROSSED the line after HURDLING, then you would get two more points.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
MNov's Avatar
AKA: Matan Nov
If it carries the ball over the line, and releases it on the other side, would it get the 6 bonus points, even if it didn't get the 2 line crossing points?
Unread 06-01-2008, 15:11
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
nope
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 06-01-2008, 15:17
tlawless's Avatar
tlawless tlawless is offline
FRC #0027 (Team RUSH)
tlawless is an unknown quantity at this point
I think it's best to break up the scoring into points earned by trackballs and points earned by a robot. The diagram in section 7.3.3 helps a lot.
If your robot is holding a trackball and crosses your alliance's finish line, you would not get any points for the trackball UNLESS a robot from the opposing alliance touches the trackball as it crosses the line. Since your robot is crossing the line, assuming it crosses fully, your robot earns 2 points (in teleoperated mode).
If you touch a trackball at any time during the trackball's "Crossing" of the finish line, then the ball is worth 0 points. The rules don't state this very well, but I'm assuming you BEGIN to 'Cross' the line when the vertical plane is breached by the trackball. Likewise you finish 'Crossing' the line when the last part of the ball crossed the vertical plane per the manual:
"A TRACKBALL or ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counterclockwise direction, have completely passed through the plane."
I'm not entirely sure about the third question, I'm wondering about the answer myself. Are you allowed to cross the finish line with a part of your robot during the act of HURDLING?
Hopefully this helps, and is accurate! This is how I've come to understand the scoring, verification would be appreciated!
Unread 06-01-2008, 15:21
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Thanks.
I believe the team gets 2 points for the robot crossing their finish line even if it has a trackball in its possession. <G06>
The combination of rule <G10> and definition of a ball CROSSING the line leads me to believe that no points would be awarded for contacting a ball while it is crossing the line (this is going to be tough for the refs to call).
If the long-armed robot maintains contact with the ball after crossing the line, it did not satisfy the requirement in the definition of HURDLING for having the ball contact the floor or another robot before contacting the originating robot (i.e. the ball must be released before it crosses the line): 0 points for the trackball.
These interpretations are mine and could be wrong! The FIRST Q&A should be consulted for official responses...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 06-01-2008, 15:24
MNov's Avatar
AKA: Matan Nov
Alright, thanks everyone.
Sorry if I'm a little slow >.<
Unread 06-01-2008, 16:54
byrnedfish byrnedfish is offline
AKA: KFish
FRC #2228 (CougarTech)
byrnedfish is an unknown quantity at this point
In this picture the robot has possession of the ball as the ball crosses the line (as it is hurdling). Does this mean the ball gets the 6 bonus points because it hurdles and loses the 2 points because it crosses the line in the robots possession?
hmm... looks like this might be another rules discrepancy.
Tell me if im interpreting something wrong
Unread 06-01-2008, 17:11
Tottanka's Avatar
AKA: Liron Gurvitz
This is counted as 8 full points.
There are also 2 additiona points for the robot crossing its own Finish Line immediately after it.
You can easily see in the table of the scoring in "The Game" that there is no possiblity of 6 points at all. only 8.
Unread 06-01-2008, 17:16
MNov's Avatar
AKA: Matan Nov
See, now this is a problem, he shouldn't get 2 points, because he didn't "legally" cross the finish line, so the question I'm asking is whether or not the 6 bonus points can be standalones, or are they dependent on the aforementioned 2 points.
Unread 06-01-2008, 17:18
So it's either 8 or 0. I think a new definition is needed: Over the overpass.
Tottanka's Avatar
AKA: Liron Gurvitz
I cant see why you think that he did not cross the line illegaly.
Could you bring a quote from the Docs?
Unread 06-01-2008, 17:21
MNov's Avatar
AKA: Matan Nov
Read the original post, he's touching the ball while it crosses the line, no points for that.
BTW, were you at the kickoff in the Air Force center today?
Unread 06-01-2008, 17:22
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
2 points.
<G11> Each TRACKBALL that HURDLES its own FINISH LINE will earn 8 points (2 points for
CROSSING the FINISH LINE – re Rule <G10> - and a 6 point bonus, yielding 8 points
total).
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Finish the Sentence IV! Jeff Waegelin Games/Trivia 22 15-06-2005 10:44
Finish the Sentence II Jeff Waegelin Chit-Chat 321 27-05-2003 16:23
Finish that line Aaron Lussier Chit-Chat 75 14-07-2002 08:58
Team 131 "crossing the line" archiver 1999 1 23-06-2002 22:03
