Go to Post Anyways, before we all get worked up over this setup, let's wait and see what details emerge. It can't be as bad as everyone is making it seem. - Karthik [more]
Unread 06-01-2008, 16:58
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
A Tip for the PDB
Here is a tip that I believe most teams would enjoy when it comes to the power distribution block.
Kris Verdeyen's Post
Originally Posted by Kris Verdeyen
We went through a process of:
1. Removing the crappy slotted screws from the PDB.
2. Turning down nice caphead allen screws on the lathe so that they'd fit in the plastic housing.
3. Crimping and soldering on the end of each power wire an Anderson Power Pole pin.
4. Sanding and bending the pin slightly to become a hook that will fit flat into the PDB.
5. Tightening down the nice new capheads on top of the modified APP pins.
6. Locktite the screws from the side of each PDB section.
7. Tape the part of the APP connector that sticks out from the PDB
This process took an entire fixit window to complete, and although it was tedious and slow, we had not a single problem at the championship, after constantly fixing it at both of our regionals.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 06-01-2008, 17:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: A Tip for the PDB
I recall seeing another post on the subject that was more like what we did, and we had no problems with the PDB wiring:
1. Strip the wire to the recommended length.
2. Tighten the set screw to the recommended torque.
It's not rocket science....really....
Unread 06-01-2008, 18:21
DonRotolo's Avatar
Back to humble
FRC #0832
We did not have any problems at all last year, and we went to 2 regionals and Atlanta.
We did use a torque screwdriver though.
Don
Unread 06-01-2008, 22:04
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
This process does seem like overkill a bit, but probably has great results.
Last year our main battery wire came out during a match, but we had no further problems after tightening all the screws, and re-tightening after every match.
Unread 06-01-2008, 22:20
Please remember that you may not modify the terminal block other than removing the unused sections and cutting the jumper to length.
What you should do:
Strip the wire to expose 5/8" yes that is long but it is the specified length.
Insert 1 #6 only in a terminal.
Tighten the screws and pull on the wire to make sure you have fully inserted same.
Secure wire with a tywrap near the terminal block.
Use the center block to connect to the power input so that current is split by the jumper and not carrying full robot current.
Check the manufacturer's website for further info.
What you should never do:
strip less than 5/8", 1/4" is a guaranteed failure.
Insert more than 1 #6 wire in each terminal.
Tin the wire before insertion.
Fail to insert wire until it comes to the designed in mechanical stop.
Attempt to reinsert a wire before fully unthreading the screw and checking for clearance in the terminal block.
Use a block that is damaged or has melted.
TEAM TIP: Holiday Food Drive! Rich Wong General Forum 0 20-11-2003 01:30
2003 Robot Machining Tip Matt Reiland Technical Discussion 1 14-11-2002 12:54
I tip my hat to all rookie teams archiver 2001 2 24-06-2002 02:25
Grady personal injury avoidance tip #2 archiver 2001 27 24-06-2002 00:05
Web Site Update Tip archiver 1999 0 23-06-2002 22:37
