Go to Post That sounds like PONG. For you youngsters, that was the first video game available for the public to play. - Robert Cawthon [more]
Unread 06-01-2008, 17:01
travmizer's Avatar
travmizer travmizer is offline
Head of Programming
AKA: Travis Schmidt
FRC #0617 (Springer Express)
travmizer is an unknown quantity at this point
Send a message via AIM to travmizer
Head's up Robocoaches
Ok, just for the record, no infrared jammers. That means TV-B-GONEs, alright?
Gracious Professionalism!
Isaac Asimov once said:
If knowledge can create problems, it is not through ignorance that we can solve them.
Unread 06-01-2008, 18:38
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: Head's up Robocoaches
TV-B-GONEs are not jammers. and if they accidentally block out other peoples signals, well then that's the other teams problem. Yes, people should be considerate, but if a team wants to use a TV-B-GONE, then there is no stopping them.
Unread 06-01-2008, 18:40
MNov's Avatar
MNov MNov is offline
Giant deceptive face
AKA: Matan Nov
FRC #2230 (Zacharia's Angels)
MNov is an unknown quantity at this point
I'm fairly sure that there's something in the rules about sending signals to other robots.
Not to mention that if one of the refs finds out you're using a signal, you'll get kicked out of the competition before you can even switch it off.
Unread 06-01-2008, 18:45
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
For fun I built a TV Jammer and it did work but only from about 6 inches from the receiver.
Video I got the idea from: http://www.metacafe.com/watch/881875...e_jammer_hack/
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 06-01-2008, 18:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I think you would be well advised to understand how easy it is to see infrared being broadcast. In fact, you can by inexpensive real-time cameras that will show you pictures in the infrared.
You might get a little surprise if you try to interfere with the competitions.
But that's just a guess.
Unread 06-01-2008, 18:48
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
You are not serious are you?
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 06-01-2008, 18:50
Who's got a cell phone camera? On at least some of them, you can see IR transmissions. (I tried it earlier at home--also tested a fire alarm by mistake.)
Unread 06-01-2008, 19:01
keen101's Avatar
Ubuntu Linux User
Serious about what? I'm not planning on using a TV-B-GONE, I was just stating my opinion.
But, i may try one out with our robot in testing, and see if it can be programmed. (Maybe it can, but more likely it can't... in which case i guess it could be considered a jammer)
Unread 06-01-2008, 19:04
keen101's Avatar
Ubuntu Linux User
Even IF someone were to try and interfere, and the refs or someone had a camera that could see IR transmissions. What would make them suspect that person of jamming, and not just sending a contiguous signal to their robot?
Unread 06-01-2008, 19:12
Dr Nick Dr Nick is offline
FRC #0501 (The Powerknights!)
Dr Nick has a spectacular aura aboutDr Nick has a spectacular aura about
Send a message via AIM to Dr Nick
As far as I know, the "TV-B-GONEs" just send the turn-off code for many different models of TVs so eventually the one you are pointing it at will turn off. The only way I could see this as breaking the rules is that it sends more than 4 commands (albeit with only one button) but they don't "jam"the infrared spectrum.
This does bring up an interesting issue I was thinking about that by the sounds of it, the IR receiver only works with so many brands of remote controls so if two teams were using the same button, wouldn't they inadvertently interfere with the other team's robot?
Unread 06-01-2008, 19:27
keen101's Avatar
Ubuntu Linux User
That is a strong possibility.
Two robocoaches paulcd2000 Rules/Strategy 4 05-01-2008 19:10
998's Website (Just a Head's up) D.Viddy Website Design/Showcase 1 28-02-2004 19:19
