Go to Post FIRST is not about a robot competition . . there just happens to be one at every FIRST event. - Stuart [more]
Unread 06-01-2008, 18:55
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Are you considered in the homestretch if?
Originally Posted by Caseavong View Post
Goodness,
i think should repharse this question.
I meant if you wanted to descore your opponents trackball backwards with a mechanism, after passing there homestretch would it be legal?....OR would that be considered breaking that 6' in there homestretch?
well the rule states that you cannot break the plane of the line, and although you are moving in a counter clockwise direction you arm will break the plane of the line in a clockwise direction therefore breaking the rule
and if your arm doesn't get all the way over the line you are still in the homezone.
Are Servos Considered Electric Motors? Calvin_1631 Motors 7 15-02-2007 03:17
When are you considered a rookie entry? jfelser 3D Animation and Competition 3 01-02-2006 01:17
Are Grommets considered fasteners? kmcclary Off-Season Events 1 04-11-2001 17:26
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
