Go to Post It is possible to live without the Big sponsors, it just takes a lot of fund raising and hard work. - Raumiester2010 [more]
Unread 06-01-2008, 19:06
Re: Moving Backwards
Originally Posted by richalex2010 View Post
Also, there is a 4 point penalty for going backwards across after you've already crossed fully. We decided that it might be worth it if you have to go back to assist a trackball over the overpass.
(emphasis mine)
Show me a four-point penalty in the rules. The only ones listed are 10 points, disable, DQ. Worth it? Maybe. Probably not.
Unread 06-01-2008, 19:11
richalex2010 richalex2010 is offline
AKA: Jake Alexander
FRC #0177 (Bobcat Robotics)
richalex2010 will become famous soon enough
I'm not sure where it is (if it exists), as I never saw it. That's what we had discussed today, though, and no one said anything to refute it, so I assumed that it was in there somewhere. I'll take a look and post something if it is there, though.
EDIT: Looks like you're right. There is no 4-point penalty; it's 10 points, deactivation, or disqualification. It is not worth it to travel back over the line at any point. I'll bring that to the attention of my team. Thanks for pointing that out, Eric.
-Jake Alexander
Unread 06-01-2008, 21:00
MGoelz's Avatar
MGoelz MGoelz is offline
Miranda: Design and Scouting
FRC #0234 (Cyber Blue)
MGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond repute
Send a message via AIM to MGoelz Send a message via Yahoo to MGoelz
Moving Backwards as long as you're in a quadrant
CROSSING: The act of a TRACKBALL or ROBOT passing through the plane defined by a line (i.e. LANE MARKER or FINISH LINE) when it is projected vertically upwards. A TRACKBALL or ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counterclockwise direction, have completely passed through the plane.
<G22> Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
Based on rule <G22> and the definition of Crossing, there is nothing wrong with moving anywhere within a quadrant, as long as you don't break the plane of the lane divider lines or finish lines.
If you cross back a 10 point penalty will be applied, and if you start to cross the next line (moving counter-clockwise), then you probably want to keep going so no penalty can be applied.
I haven't found a rule against moving freely in a quadrant, providing you don't break the planes dictated by the lines.
"The ideal engineer is a composite ... He is not a scientist, he is not a mathematician, he is not a sociologist or a writer; but he may use the knowledge and techniques of any or all of these disciplines in solving engineering problems."
— N. W. Dougherty
Backwards motor paulcd2000 General Forum 17 14-02-2006 18:18
Camera tracks backwards BobC Programming 7 16-02-2005 10:59
Starting Facing Backwards? Fusion364 General Forum 8 21-01-2005 11:31
Relay Aliases Backwards Jeff Zampieron Programming 19 18-02-2004 16:27
Backwards auton_mode David Bing Programming 2 05-02-2003 23:23
