Go to Post FIRST for me is getting to opportunity to learn from the smartest people I know, the mentors. - faust1706 [more]
Unread 05-01-2008, 21:19
eastsideboma eastsideboma is offline
None #2016
eastsideboma is an unknown quantity at this point
Question Throwning the ball over the over Pass
Is it possible to throw the ball over the overpass? And if so are there any velocity or safety restraints?
Unread 05-01-2008, 21:26
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: Throwning the ball over the over Pass
I have not seen anything in the game rules saying that you cant catapuls balls. I have also not seen anything about restraints either. It is also possible that I just completely missed them both. I dont think they are too worried about a velocity though. I dont think that ball will be able to go yery fast, I think if you launch it it will just kind of float like a beach ball, however I have not got to see one of the balls up close yet. None of these are definate facts, so take them for what their worth.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 05-01-2008, 21:37
None #2016
ok thanks i was just wondering if it was at all possible. because to have a 10 lb ball flying through the air there might be some restrictions
Unread 06-01-2008, 06:58
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
alright our team has been discussing this option a lot...but I realized that the catapult idea wouldnt work if they wanted to say...hurdle...the ball
first off, in the definition of hurdling, it states "be moving toward the OVERPASS and/or elevating the TRACKBALL so that the top of the
TRACKBALL is higher than the LANE DIVIDER."
that means ure catapult will have to start at 6 feet (ht. of lane divider) in order for your robot to succesfully hurdle
correct me if Im wrong...
Unread 06-01-2008, 09:00
AKA: Joey
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS
and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
You are right about the hurdling part, but not about the hurdle part. Nowhere in the definition of a hurdle does it say that you need to be in the process of hurdling. I see it that they are two seperate things. All being in the process of hurdling is protection from contact with other teams robots.
Joey
Unread 06-01-2008, 10:14
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
well the trackball itself is 40 inchs high on the ground, giving the facthat it is the "TOP" of the trackball must be over 6ft.
the ball is already 3' 8" without any support so really the catapult only needs to hold the ball up another 2' 4" which realy isn't a big deal!
Unread 06-01-2008, 11:31
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
You said it yourself, "and/or". You are hurdling when you are in your home stretch, in possession of a Trackball and moving towards the overpass (you do not need to have the top of the Trackball above six feet). G42 gives you protection while in the act of hurdling. The rules do not say you have to be in the act of hurdling (by definition) to hurdle. A hurlde is when the Trackball passess above the overpass (nothing more, nothing less) and will be scored if over your alliances overpass. For that matter, I do not see anywhere where it says that the Trackball must pass over in a counterclockwise direction, wow, does that open up possibilites! Please, someone correct me if I am wrong.
The rules could care less about how a Trackball gets above an overpass. You should be able to use a catapult, even if you are setting still and the top of the Trackball is not six feet off the ground. You will not be getting the protection of G42 if you are not moving towards the overpass tough.
Unread 06-01-2008, 18:34
None #2016
yea your right i dont see anywhere where it clearly states that you have to throw the ball in that motion which leaves alot of options open
Unread 06-01-2008, 19:01
ccsingle07 ccsingle07 is offline
AKA: Cody Cannon
FRC #0830 (Rat Pack)
ccsingle07 is an unknown quantity at this point
Send a message via AIM to ccsingle07 Send a message via Yahoo to ccsingle07
So that means that if............
/ Robot was | \
/ O <- here | \
|_____________ | ___________ |
| Alliance | Ball could |
\ Home | be thrown /
\ Stretch | here -> O /
...........and still count as a hurdle. As long as it passed over the alliance's overpass,
Our team believes it would, and the only down fall was that the robot wouldn't be considered "hurdling" and under the protection.
*If I'm wrong please let me know. I don't see anything wrong with it though.
paragon571's Avatar
paragon571 paragon571 is offline
AKA: Linnea
FTC #0130 (blazing spirits)
paragon571 is an unknown quantity at this point
Today team paragon tried a mock game with students and a ball. We tried to toss the ball over the overpass but it didn't work out to good we only got it once. Also when we threw it over after the field was built someone got knock down on to the floor.
Unread 06-01-2008, 19:07
AKA: Joey
No you cant throw the ball over backwards, look at the definition of crossing
CROSSING: The act of a TRCKBALL or ROBOT passing through the plane defined by a line (i.e.
LANE MARKER or FINISH LINE) when it is projected vertically upwards. A TRACKBALL or
ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counterclockwise
direction, have completely passed through the plane.
You can throw the ball backwards over the overpass, but you wont get any points for it.
Joey
Unread 06-01-2008, 19:11
AKA: Cody Cannon
My last post had a text picture that did show up so below should be a corrected pic.
Apparently spaces don't show up????? ????????
................/ Robot was.....|...................\..................... ...........................
.............../ O <- here.......|....................\................. ..............................
..............|_____________ | ____________|..................................... ..........
..............|......Alliance..... |....Ball could....|........................................ ......
...............\......Home........|...be thrown..../...............................................
................\....Stretch......|.....here -> O /................................................
Unread 06-01-2008, 20:06
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
to ccsingle07
yes, I think. It is traveling counter-clockwise, so I see no problem with this.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 06-01-2008, 20:18
King Duke's Avatar
King Duke King Duke is offline
FRC #0991 (Dukes)
King Duke is a jewel in the roughKing Duke is a jewel in the roughKing Duke is a jewel in the rough
Send a message via AIM to King Duke
anybody know of a fairly reliable formula for figuring out air resistance on the ball?
I've looked up the formulas online, but all I'm able to find is "high velocity" formulas and I'm not sure what exactly a "high velocity" would be.
Mr. Ames
#991 The DUKES!!!!! from Phoenix, Arizona
Cornell MineSweeper- Business is Booming.
Unread 06-01-2008, 20:54
dtengineering's Avatar
AKA: Jason Brett
Unless I have messed up my kinematics, an initial velocity of 6.25m/s should launch an object 2m into the air, which should be plenty for hurdling. Given that this is about 23km/hr, I suspect you could adequately account for air resistance by just aiming to put the ball 30cm or so over the crossbar.
Now how you accellerate the ball to 6.25m/s... that's another issue.
Jason
What is your team going to do with the rack after the season is over? Ben_pharteen General Forum 51 14-04-2007 15:27
What will the winners have over the rest of us Ben Lauer General Forum 21 26-02-2005 00:17
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
Knocking over Ball via Tee tminard Rules/Strategy 2 07-02-2004 11:35
Height of the bar over bonus ball structure punarhero General Forum 3 17-01-2004 14:39
